my mobile oiginally has 20 MB of phone memory.. but wen i checked, it shows only 18.94 MB... my friend told that it was due to virus problem..
so i like to fomat my phone memory. My questions are
1) Is my mobile attacked by any virus?
2) How to format phone memoy?
-   I have Nokia 7500 when I try to add new acount, I get this messege ( cannot add new acount. Memory full) and when I check default setting is empty. Please any one help me and email me habukar@hotmail.com-   Hiddig
yeah there are some kind of applications which are hidden and consuming ur all phone memory, sou now need to format ur phone memory. but before formattiing ur phone memory, save ur all contacts and other data which is in ur phone memory once it is formatted then u will loose ur all contents in ur phone memory, to format ur phone follow this. apply this code *#7370# , it will ask u resetting will change all ur phone settings to original. select yes. once u will press yes it will prompt u for security code. fill security code ur phone screen will turn to big nokia logo for meantime once will get formatted ur phone will start. best of luck don't forget to rate my solution.
Best Solution :
RESETTING PHONE BY NOKIA SECRET CODES (steps 1 and 2)
1st step : SOFT RESETTING NOKIA MOBILE
Take backups of ur phone books,calender and others, then
simply enter the code
*#7780#
2nd step : HARD RESETTING BY CODE
Just enter the code-
*#7370#
Then it asks for security code enter ur security code whose deafault value is
12345
NOTE:
The battery must be full or the charger has to be connected to the phone so
that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
FLASHING
3rd step :FLASHING: ANOTHER METHOD FOR
HARD FULL FORMATTING
This step is known as flashing of phone. Always do this step at last (after 1st
2 steps are over and u are not successfull)
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be
left)
2. Backup your contacts list and personal files to MMC memory card (if
possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
then press the power on/off to swtich on the phone.
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at
its original factory settings (It will reach the same state as that in when you
purchased it).
------------------------------------------- Please let me know your feed-back.
How do I delete a picture that was set as wall paper. I do not want to replace. But delete it. IAm...
(More)
How do I delete a picture that was set as wall paper. I do not want to replace. But delete it. IAm using N 72 model
i realise my nokia n72 has the im feature,would i be able to chat online with friends?if yes how am...
(More)
i realise my nokia n72 has the im feature,would i be able to chat online with friends?if yes how am i to set it up?
I want to delete some data in N72 bt it does nt delete.
Comment by Guest, posted on Jul 19, 2008
My Nokia N 70 having 20 MB Phone Memory, but know it will SHOWS 17 mb USED
PLZ HELP
Comment by Guest, posted on Jul 17, 2008
Mu chellphone show error Memory full please delete some data". When i try to open any application like masage box or galary or music it shows operation failed low memeory delete some data first. please help me what i do.
can u tell me how to install a theme directly from pc. i can install it manually by file manager and then install it. but i' ve seen some of my friends directly install themes and other application on nokia multimedia sets. im using nokia n73. i think u can solve my problem. Plz help me.
my phone memory is full now, so i want to format it to clean my phone memory. I knw if i delete some items from phone memory, it will be fine.
but i wanna clean it completely. but i dnt knw how to format phone memory. so plz tell me the process to format phone memory.
