Question about ASUS F3Jm Notebook
Can't get by the windows log in screen
I have an old work lptop that I was going to let the kids use. However when I pwr up I can't get past the windows log in screen. Its been about 2+yrs sine I've used this laptop and have no remote chance of recalling login at that time
Any way to reset or boot past this?
Hi
I've purchased a new Asus laptop and everything was fine until I installed Nortons. when I rebooted after the install as instructed I can no longer log in.
Can anyone help
  • 1 more comment
  • Dracer Feb 23, 2008
    Unfortunately neither of these solutions solved the problem.
    I didn't get a CD with the machine when it was purchased so I couldn't use Justababe's solution.
    Are there any other ideas out there?
    Dracer
    When I start in safe mode it eventually takes me to a welcome screen that has an adminstrator icon and my own login icon. As soon as I select either I get a msg that says 'loading your personal settings'' then immediately says saving your personal settings and so we go back and forth.
  • loralann Apr 30, 2008
    I have the verry same problem
I could not get past my own passwork - somehow my password got changed and I did not change it. I tried solution #1 and IT WORKED!!!! THANK YOU!!! I am no computer expert and I was able to go through it and follow the instructio written with no problems. Thank you.
Posted on Jul 11, 2008
Thanks for your help everyone I've decided it's probably best to take it to an IT centre and have it repaired.
Dracer
Posted on Feb 23, 2008
Both of these problems are different. I'm working on the inability to log in because of a forgotten Admin password.
Cluster is right...boot to safe mode and uninstall Norton...
Immediately upon starting your computer...start pressing F8...you will see a screen with 5 options
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last known configuration (settings that worked last)
Start Windows normally
Choose Safe Mode....and proceed to safe mode. it may take a few mins for your os to load the bare drivers and you will see them scroll on the screen, but continue to wait . It will boot to safe mode.
Once in safe mode, Uninstall Nortons then reboot...
Now, on the first solution--what happened when you followed the directions? Please submit...
    Sniper:
  • 67 Answers
Restart your computer
press F8 before windows starts up...you can start pressing F8 a couple of times a second or two after you turn the computer on.
you will see a menu....then select "last known working configuration"
if this doesn't fix the problem then reboot and press F8 all over again but this time select "safe mode" and it allow you to get into windows.
go to the "control panel->add/remove programs" and remove norton and anything else with the name norton in it.
in my experience norton is a resource hog, i would suggest avg or something of that sort.
  • clusterfx
    clusterfx Feb 23, 2008
    are you running windows xp or vista?
    Scholar:
  • 117 Answers
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
  • 1 more comment
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Feb 23, 2008
    Dracer, Did your laptop come with a "factory restore" option. What kind of "old" laptop is it.
    Draven, Read and try this solution...
    Windows Password recovery
    http://www.loginrecovery.com
    This site provides
    a tool to recover lost Windows XP passwords. It
    works for administrator and user accounts, it
    doesn't change the password just tells you the
    old one. It works with encrypted files (EFS) and
    password hashes. It even works if no passwords
    at all are known for the machine (as long as you
    have another computer with internet access to
    view this website with).
    Author claims it
    also works with Windows NT and Windows Server
    2003 and Windows Longhorn, but the BEST thing
    about it is the fact that it won't reset your
    passwords, but simply reveal them for you to
    remember and then use.
    Give it a try. The
    author would like to receive feedback. There is
    a free service as well as a priority service
    that will retrieve your passwords within
    minutes. The fee for the priority service is
    very cheap, and is really just to cover server
    costs.
    Note:
    You'll need a blank floppy to run the process.
    Update:
    Author now offers the same tool as a CD image
    for those of you who do not have a floppy in
    their computer.
    Usage, instructions and additional information
    can be found at
    Terry Lynn Deschamps Feb 24, 2008
    Since you do not have an OS CD...try this option
    http://www.loginrecovery.com/
See by the moonlight it's quarter past midnight time kid and I were home and hour and a half ago
The verse seems to be from a New England Folk Tale "The Old Woman and her Pig" - http://courses.wcupa.edu/johnson/tales/womanpig.htm
However, you will see that your version is not there, although something similar is.
The following verses are probably a more accurate:
"As I went over London Bridge
I lost a guinea and found a kid,
and the kid wouldn't go.
See, by the moonlight,
'tis half-past midnight time kid
and I were home an hour and a half ago.
"Then I went along a little way, and I found a staff; and I said,
'Pray, staff, lick kid; kid won't go," etc.
In still another telling, the old woman, instead of remarking the lateness of the hour by the moon, says,
"Piggy won't jump over the stile,
and I sha'n't get home in time
to get my old man's supper to-night."
Nov 16, 2017 | The Computers & Internet
Hp laptop window 10 or vista or is that the samething... ok well i need to get past the login / password screen.
hello,
is this a 10 or 20 year old LT? or new?
it has a real Name on the sevice tag on the bottom
or inside battery bay, battery out.
ok cant log in, W10 is never ever VISTA, sorry.
there are 2 windows 10 logins
one is called local.
and other is you always must login to windows.com
if its at windows actual
you must go to your email there, and ask for a reset of the online pass word,
google how to reset windows 10 pass work at microsoft
1billion hits, seems every one does this.
and now write it down on paper.
here is the live fix.
https://account.live.com/ResetPassword.aspx
THIS PASSWORD?
if you use the cloud or windows store, bingo above.
May 13, 2017 | HP Computers & Internet
My lptop cam driver deleated by mistake so my kids cant see my pic on line with cam on
see if u have system restore that will restore it if not go to manufacturer website and re download it
Feb 20, 2011 | Computers & Internet
My son passworded my hp lptop while he was home from Afganistan. I tried to use my computer today but I can't get past the sign in screen that asked for user name and password. I haave no idea what he...
Power on pc->immediately start tapping the F8 key on keyboard->select safe mode->press enter->login as administrator(password might be blank, u can give it a try).If successful u would be on a desktop screen with safe mode on all four corners.Now go to start->control panel->useraccounts->select ur son's account and remove the password.This is worth a try.If it doesnt work the only option is to reinstall the windows(if u cant remember the pwd for your son's login)
regards
Abhilash
Sep 20, 2010 | Computers & Internet
PLEASE HELP !!!!!!!!!!!!!!!!!!
1) Use the vista DVD to go to the repair mode.
2) From the same screen where you do the system restore, there's an option to open an administrative command prompt.
3) That should open in X:\Sources or something like that
4) Go to the windows drive by entering C:
5) Now go to the windows event log folder on your machine (C:\Windows\System32\winevt):
cd c:\windows\system32\winevt
6) ren Logs Logs_bad
7) mkdir Logs
This will create an empty folder for new event logs.
Restart the system. Hope this helps
-CompDoctor
instructions from website here
Feb 22, 2010 | Sony VAIO VGN-N250E/B Notebook
I have an IBM thinkpad That will not boot to windows. The screen remains blank.
have you tried booting it from a cd,you might hve to go into the setup and tell the lptop to boot from cd first
Feb 17, 2010 | Computers & Internet
MAC Kid Pix Problem loading Animations and stickers
The solution for Mac OSX is here:
Click here:
Kid Pix Deluxe® 4 Update for Apple® OSX
or
Copy and Paste this link into your browser:
http://support.riverdeep.net/brodcastdl.asp?dlid=709&id=
The solution for Windows is here:
Click here:
Kid Pix Deluxe® 4 Update for Windows®
or
http://support.riverdeep.net/download_desc.asp?dlid=708&id=1294820708
Hope this helps!!!
Nov 06, 2008 | Riverdeep Kid Pix Deluxe 4 (kidpix4) for...
Assuming you did not set an administrator password - you can hit the F8 key when booting - and then select Safe Mode. Once the machine boots to safe mode, you'll be able to login using the Administrator account, and you can go into the control panel to change the actual user's password.
If you did set an admin password that you do not recall, you can use Petter Nordahl-Hagen's Offline NT Password & Registry Editor to reset the Admin password.
Jan 25, 2008 | Dell LATITUDE C640, P4...
Windows XP Log In screen removal
Try removing the machine from the domain first. Right click on my computer, go to Properties, go to the Computer Name tab, and where it says " To rename thic computer or join domain, click Change", click on the Change button.
In the following screen, select Workgroup, give it any name and click OK.
Before you do this, make sure you have an account with admin privileges on the local machine (make sure you know username and password for this account).
Nov 16, 2007 | IBM ThinkPad T40 2373 Notebook
ASUS F3Jm Notebook Logo
403 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
