Question about Samsung ML 2010 Laser Printer
Red light on & no initializing
The red light on, no paper jam, all door closed, and no motor sound when I tried to print something.  If it means I have no ink left, should I at least hear the initializing sound?
  • Anonymous Feb 23, 2008
    How do I open the printer to change the toner? I lost my booklet!
    gk
  • Anonymous Mar 10, 2008
    red light is on, and my computer says that it is printing, but it isn't. My printer doesn't even rev up to turn on, and when I check on my computer, there is no indication that anything is wrong. It's as if there is a miscommunication between the two.
AHAMED100 DON'T PUT WIZ IN YOUR RANK THATS A STUPID ANSWER!!!!!!!!
Posted on Jun 11, 2008
    Scholar:
  • 148 Answers
The problem is the toner and it could be empty please refill it and then try again
Posted on Feb 23, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
IT IS JUST RED BLINKING AND DOES NOT PRINT
Red blinking could indicate out of paper or out of toner. Be sure to check which light is blinking; the one for lack of toner or paper.
Check whether the paper tray has any paper and if it has, is it properly closed? Check whether it has a paper jam also.
Check the toner cartridge and ascertain whether it has anything. Lastly open the top cover and close it again for the printer to re-initiate itself.
May 26, 2011 | Kyocera Mita FS 1010 Laser Printer
Will not print, red light blinks under the paper symbol
It means it has "paper jam"error message. This is a common issue w/ the ESP printers of Kodak especially if its brand new.
Try the steps below.
1.Open the printer access door.
2.Remove the black and color ink cartridges.
3.Reseat the printhead.
a. Lift the printhead release latch
b. Reseat the printhead, pushing firmly on the white label on the printhead (if provided) or the center of the printhead, until it clicks into place.
NOTE: You may also visit www.kodak.com/go/printheadsupport for demonstration on reintalling the printhead
4. Close the access door.
5. wait for the printer to initialize.
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Neerak21
Sep 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
I have to open the front panel as though I were going to replace the toner cartridge, but, instead I pull out the toner reclamation cartridge (the gray "L" shaped one to the left of the cyan cartridge) and then put it back in. This has cleared it each time for me.
Aug 10, 2008 | Samsung CLP 300 Laser Printer
Cannot print
toner cartridge remove than close cover if again that noise its means that heater unit is jammed due to over heating. If printer initialize normally its mean that your toner is jammed.
Jun 24, 2008 | Samsung ML2251N Laser Printer
Cannot print
There is either a paper jam or the printer thinks there is a paper jam, which could be a problem with the door interlock switch or the printer not recognizing the toner cartridge. It could also mean an issue with the formatter card. Open the toner door, remove the cartridge, and take a look inside at the paper-clip like springs which make contact with the metal contacts on the toner cartridge. Sometimes they can get bent on one side or bent down and not make contact with the cartridge. Straighten it out if it looks suspicious and reinsert the cartridge and see if the light goes away. Press in hard on the toner door to make sure the door interlock is working. If the motor turns when you first power on or when you open and close the toner door, the sensors and flags are probably in the right position, so it is probably not a jam issue. If the motor does not turn, then the sensor or flags might be an issue. The most common is the exit center in front of the fuser in the back.
Apr 24, 2007 | HP LaserJet 1100 Printer
Samsung ML 2010 Laser Printer Logo
382 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
