Question about Pioneer CDJ-100 Turntable
Cdj 100s hi, i have just recived a pair of cdj100s by post and they both appear to have the same problem, the cds won't go into the machine, just wondering if there is some sort of reset button. plese help. cheers chris
  • asteras8 Feb 24, 2008
    it does not recognise the cd
  • Anonymous May 29, 2008
    i got a one pair of cdj-100 one of them have a problem i cant eject the cd inside the unit i used key to eject it. is theres a replacement parts of cdj-100 to buy here in the phil?
Hey, the only way is to open your cdj100s and align the white plastic back into its position. Then put some oil on all the moving parts to lubricate. Dj A.D Zeal
Posted on Jul 27, 2008
Hi! my pioneer cdj-100 has not ejecting cd
Posted on May 29, 2008
Cdj 100 is playing only original cds
COPY CD / AUDIO (NOT MP3) WITH GAPS ... X 4 SPEED OR LESS
Jan 05, 2013 | Pioneer CDJ-100S CD Player
Eu tenho o cdj 100 s pionner que deu problema no leitor troquei os leitor uma funcionou e a outra não o que sera me ajude
hello frnd,
can u pls post ur complete problem. what error u get. does cds play or not. how old ur cdj's
thx
Aug 07, 2010 | Pioneer CDJ-100S CD Player
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
Pionee cdj-100s jog seems to be lagging
pull the jog wheel off and give it a clean and some grease on the shaft, also don't push it back down the whole way
Aug 26, 2009 | Pioneer CDJ-100S CD Player
Cd error and ejecting
There is a problem with the motor that ejects the cd out!you start getting those error because you put mest up cds in your cdj!You need to always make sure there clean and not scrtch too bad specially with old cd decks like the 100!
Aug 25, 2009 | Pioneer CDJ-100S CD Player
How to mix cdj 100s with my p.c virtualdj?
hii,
u cant connect cdj 100s to you p.c as it does not have supported software to connect to P.c
Mar 28, 2009 | Pioneer CDJ-100S CD Player
Cdj-700s
Hi Je remy
I have a 700s too, it´s showing problems similar to yours. Mine is even worst, it almost doesn´t play no more (shows "NO DISC"). Sometimes, when i turn it off and on, or open the cover, it reads... When pause is pressed, it holds the music for some seconds, then it "slides" thru the music... Sometimes it display an error message (something like E-8something).
I think all these errors are caused by a worn optic reader, but i´m not sure. I´ve already opened my unit and cleaned the lens, but no bail.
Here in Brazil a new optic reader can be found for R$150 (around U$90). I´ve just found out the same unit in UK for 150 pounds, so i´m suspicius that those units sold here aren´t really new... I´m planning to replace mine, but first i must be sure that the problem is really caused by the reader.
I don´t know if u have already opened yours, but it´s pretty simple to replace the unit, just some screws to loose (12, if i´m not mistaken - 4 ouside, 4 holding the lens protective cover, and 4 holding two inox sticks where the reader slides over). 700s´ units are Part No DWY1067, and you probably won´t find those anymore. You´ll only find the DWY1069, originally found in CDJ-100s (technically almost same, but probably some newer technology), but they´re totally interchangeable.
Hope could be of some use.
If u want, can contact me at nandoseiji@hotmail.com
This is the unit seller here in Brazil:
http://www.quebarato.com.br/classificados/unidade-otica-optica-leitor-para-do-cdj100-cdj-100-cdj-100s-cdj100s-cdj-500s-cdj-700s-dwy-1069-dwy1069__181502.html
http://www.eletronicamaster.com.br/produtos.asp?produto=3991
Mar 28, 2008 | Pioneer CDJ-700S Turntable
The cd player will not load cds.
i've had cdj-100s for a while and i am familiar with cd loading issues... flip the turntable, on the underside there's a sort of key, it's ur CD eject pin, u take that and poke it in the hole in the front... that should take care of the stcuk cd, now the problem i'm having is, IMO, a derailement in the ejection system.... basically what's happening to us is that the 100s is in CD in mode... I've tried the key method, i think mine is totally all over the place, i've pressed eject and kinda pushed the cd in, i got it to run, play music (so lazer's not broke) and it would eject fine but then automatically go back to CD in mode and lock the drive.
i'm gonna take it completely apart and rebuild it... i'll post back with answers, if any!
Dec 06, 2007 | Pioneer CDJ-100S CD Player
Pioneer CDJ-100 Turntable Logo
685 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
