Question about Toshiba Satellite A135-S2276 Notebook
Toshiba My laptop keep coming with the blue screen saying memory dump contact technical support
    Brigadier General:
  • 6,966 Answers
Most Blue Screen of Death (BSOD) with memory dump is caused by memory problem or the swap file in the hard disk.
You can try removing the memory (underneath the laptop) and clean the little gold pins using a pencil eraser. It would also be helpful if the mating connectors could be cleaned using a soft new paint brush.
The hard disk, disk utility can be used to clean & repair such as Windows' Scandisk or Symantec/Norton's Disk Doctor.
In some cases this problem is also brought about by the addition of a new hardware/driver that causes conflicts. This can be verified by removing the hardware or rolling back the driver.
These problem would also surface in instances where the hard disk's OS was installed using another computer and transplanted to the Toshiba later on. No solution but to reinstall the OS on-board the Toshiba.
If your concern has not been corrected after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 23, 2008
My laptop runs for a few min then goes to blue screen memory dump page
hmmm sounds like the computer is facing a problem with the operating system or the hard drive is starting to fail on you
Dec 16, 2017 | Dell Precision M50 (PRECISIONM50) PC...
Toshiba SatelliteA70 over heating, automatically switch off, white screen problem, after a couple times it got automatic switch off, its getting blue screen error, saying that memory dumping, finally it...
DUE TO THE HOT SUMMER SOME LAPTOPS GET TOO HEATED , SO PLS USE A COOLING PAD UNDER YOUR LAPTOP. OR FOR INSTANT SOLUTION KEEP THE LAPTOP IN SLANTING POSITION SO THAT THERE IS ENOUGH SPACE FOR AIR TO CIRCULATE UNDER IT.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Toshiba Satellite A70-S249 Notebook
Hi, im using Ftec laptop and i have a problem today, when i click START it operates as usual but after a while a blue screen came out and says: STOP: c0000218 {Registry File Failure} The Registry...
it will be the problem with software...any recently which u installed....or application file has corrupted......its better to reload the system files from operating system cd
May 11, 2011 | Computers & Internet
My toshiba satellite M55-S135 is showing a blue screen with "physical memory dump complete" & to contact tech support. Basically, wanted to ask if my laptop is crashed...
Hi:
Crashed is a generic term, and the physical memory dump error is a windows based error that could be a bad memory stick, or a corruption in windows. If you have 2 sticks of memory in your laptop, a cheap and easy way to troubleshoot this would be to remove one stick, then the other,to see if one stick removed stops the crash. If it does, then you have solved the problem, and if it doesnt' then you have a corrupt software issue.
Hope you get a cheap fix!
Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
Blue screen on my inspiron 6000
your hard disk has some eror it must need fixing.u can format your harddisk with win xp recobery disk.
Mar 16, 2009 | Dell Inspiron 6000 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
Windows program shut down Laptop problem model-no-XPS M1530
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Jul 13, 2008 | Dell Inspiron 6000 Notebook
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Wireless malfunction
your wireless internet card is faulty, and your notebook sounds like its got an overload on memoy.
heres what you do:
- get a new card
and
- get a memory upgrade
hope this helps,
Maxicube
Feb 09, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
