Sansui 8700 db in safe mode
Sansui 8700 db Receiver in safe mode all else lights up no sound from speakers. All fuses are good. What is the problem?
cyrylthewolf
  • 143 Answers
SOURCE: No Sound in DTV/CBL mode
Ok... I'm still new to the HDMI input. But I'm going to take a shot in the dark on this one.
Please don't rate me poorly for this, by the way. I'd rather you don't rate me at all as I am not proposing a solution.
This is a guess. I'll be honest about that. So here goes... :P
I read through the manual a bit. (Click HERE for the manual.) I started thinking to myself about your situation...and noticed that you seem to be focused primarily on the receiver itself.
What about the Satellite receiver? Have you checked it to see if you might have to manually switch the audio output to your HDMI output? I know you have video and all, but many devices won't assume that you're switching BOTH the video AND the audio outputs. Sometimes you have to manually switch one or the other, depending on how you're connected.
I would check the SAT receiver to see if you have to switch the audio output to go out from the HDMI output on the SAT receiver.
It has always been my experience that when the speaker icons flash on the audio receiver and you're sending a digital signal to it, the receiver is in fact NOT receiving a signal...
...which obviously means that one is not being sent to it.
Please let me know what you come up with. Again, this was just a shot in the dark. But I am curious either way. :)
Let me know!
Cyryl
Posted on Nov 10, 2007
zaids
  • 456 Answers
SOURCE: Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Posted on Dec 11, 2007
sapperj
  • 70 Answers
SOURCE: sansui g5500 receiver keeps blowing fuse 5amp.
I cannot seem to find any useful information for so I'll just say this from personal experiences repairing amps/receivers. Unfortuneatley there is no good news for you.
The only reason a fuse would keep blowing is if a upstream component is bad or there is a short to ground on the circuit card. If g5500 is a tube set you may get lucky as tubes either open circuit or short circuit. My suggestion, if tube, would be to power up the unit after taking the cover off and notice if there are any tubes that light up at all, will be a quick look and a number of fuses.
BUT FIRST. BEFORE YOU TAKE THE COVER OFF ANY UNIT, UNPLUG FROM WALL AND LET IT SIT FOR 2 HOURS. This gives the unit time to discharge the large capacitors in the power supply. After you wait, then take cover off being very carefull. Notice where there are capacitors (look like miniature coke cans) or any other component, you really want to avoid touching anything, And talking about touchingif you touch a tube wash your hand real well or preferably wear gloves. The oil from our skin will cause the tube to bust because of the interaction.
Another thing you can do is follow the above procedure to remove the cover but don't turn on the power.Carefully remove all the tubes. The unit might "power on" but can't be used. This would indicate one of the tubes is bad. If it does shut-down immediately, shop time.
Pure new-age component only amps/receivers are a lot harder to diagnose as there is solder work involved to test the individual part. So this need to be done in a shop as well.
I would love to help but can't, I can only guide you a bit.
Good Luck!!!
Jeff
Posted on Jan 27, 2008
  • 3 Answers
SOURCE: vsx-516 receiver, power shutoff in safe mode, inline fuses blowen
Go to the Pioneer website, put in the model and it will prompt you the rest of the way.
Posted on Jan 26, 2009
  • 4234 Answers
SOURCE: Technics SA-DX930. I ran digital optical cable
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Posted on Mar 03, 2009
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
Sansui G-5700 protection light wont go on
Try checking the speakers and connections. Those symptoms occur if there is a short. Disconnect all spkrs, turn it on and if it stays on connect one speaker at a time until it shuts off.
Jan 19, 2013 | Sansui G-5700 Tuner/receiver
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
Center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
Feb 06, 2010 | Denon AVR-1907 Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
No output from my receiver
Some of the older radios are worth money, seeing how they are antiques, so I would research yours, make sure how much it's worth, check tube prices, try to find one on ebay or some other place, and repair it, because chances are it could be worth money.
hope this helps you out
Apr 01, 2008 | Audio Players & Recorders
137 people viewed this question
 Grubhead
Grubhead
