Question about Philips DVDR3390/37 DVD Recorder
Progressive scan I have not been able to get the progressive scan to work on two different 3390/37 recorders. The cables are correct and I have put it on the right setting. Any suggestions?
I too have tried scanning two different Philips 3390 DVD records with the same results. So far Philips have not come up with a solution. I would appreciate it if anyone out there could shed some light on this problem? It does not appear to be a one off situation.
Thanks in advance.
Posted on Mar 03, 2008
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
My zenith xbv343 dvd vcr combo has a problem when i put on a dvd it says progressive scan mode i cant see nothin else
Hello
That means the DVD you put into it to play has recordings with "progressive scan" mode. You have to change the mode of the DVD and TV which you wants to see to Progressive Scan mode to see the disc content. OK.
May 09, 2011 | Audio Players & Recorders
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Magnavox mrv640-accidentally turned on progressive scan
Had exactly the same problem. You need to reset the DVD recorder to it's default setting. The default is "interlaced".
From the users manual.........
Switching the DVD Recorder
Disconnect the recorder's power cord.
2 Hold down the FF button (arrow pointing left) the front of the DVD Recorder while
reconnecting the power cord. 'PRO' (progressive scan) will appear
on the display.
3 If you want to switch back, repeat steps 1 and 2 . 'PRO'
(progressive scan) will disappear from the display. The DVD
Recorder is switched to 'Interlaced.'
The manual is at:
http://www.m4c.magnavox.com/files/m/mrv640_17/mrv640_17_dfu_aen.pdf
See page 12
It worked for me.
Mike
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Progressive Scan Problem (works sometimes)
I had the same problem with the picture being unstable or breaking into left and right sides. I finally purchased Monster cable component video cables and all the problems went away. I can change resolution just as the product spec says. I can choose 480i or 480P or 720P or 1080i, I would try 1080P but I don't have any box capable of that resolution but I'm sure it would work.
Aug 24, 2006 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Philips DVDR3390/37 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
