Question about Toshiba Satellite A205-S4617 Notebook
Toshiba A205 help removing memory slot cover on toshiba A205. Could not remove the screw top & center on the cover - sounds like a child protected medicine bottle; rotate, click, and doesn't open. Tried lifting the cover while turning slowing- no go. Is it a trcik screw of defective? Really want ot upgrade the memory and not pay an arm and leg- had no problem replacing ram on my 600E. Awaiting your response.
  • betafish Feb 23, 2008
    thanks! I was able to use a small flat head to follow thru on your suggestions.
    Genius:
  • 3,587 Answers
Nope..that one is a little sticky..try lifting two edges at same time...while continuing to unscrew the remaining one holding it down..
check your warranty here for FREE
Posted on Feb 23, 2008
  • Patrick Michaels
    Patrick Michaels Feb 23, 2008
    thanks for the vote..can always use a 4 bagger..
A205 speaker replacement
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft Static Free cloth, on the table you're working on. Helps prevent scratching the table, and laptop.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
You're going to remove the Top Cover. BEFORE this is removed you're going to need your ESD wrist str-ap on.
Electro Static Discharge
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components in a computer.
Wear an ESD wrist strap, have it's alligator clip attached to a good ground source; and your laptop is safe from Static.
Average cost is $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The Processor (CPU) is the MOST susceptible hardware component to Static Shock!
Don't wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; and you can use your laptop for an expensive doorstop, or conversation piece. (Oh that? Yeah, Static got it")
[Page1::Page2::Page3::Find another model; is on the Top and Bottom of all pages in White ]
Go to Step 1 and follow through to Step 17 on Page 3.
The Keyboard Bezel has to be removed,
Keyboard,
Display Assembly,
Top Cover. (Palm Rest Cover),
plus the other components to facilitate removal of the above.
In Step 17 you see the Speakers. They are a large unit that can only be accessed for removal, after removing the Top Cover.
Look for a part number on them. It is a Toshiba part number.
Put Toshiba + part number, in your browser search bar, and look for replacements. (No -> + )
http://www.discountedlaptopparts.com/toshiba-satellite-a205-left-and-right-speaker-set.html
Just for a point;
The above speakers look similar (To me), to the ones in the Irisvista link. (Pictorial disassembly guide)
Searching just now out of curiosity, I saw different styles shown, for the Satellite A205.
Point being I would want to see a PHOTO of what was being sold, to see if it is the right one. A lot of ads for Toshiba Satellite A205 speakers, didn't post a photo.
Could be different speaker examples for the different model numbers, of the model series.
(A205 is the Model Series. The number/letters after that designate the Model Number)
Seems that Toshiba STSA205 is the number, but you will know when you remove the speakers.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 12, 2013 | Toshiba Satellite A205-S5831 Notebook
What is Causing my top case cover to hang up and not come off?????
Click on the photo in Step 4.
What screw did you miss?
Display Assembly is removed in order to remove the Upper Cover.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Step 12.
The Upper Cover has TABS going around the perimeter, on the inside edges.
These Tabs snap into matching LATCHES on the Base Enclosure.
(OK. Toshiba? Bottom Cover)
Just like the article, I like to start with a thick guitar pick, to get an edge to come up. I start at the Right/Middle, but it's really a personal preference thing.
After the Upper Cover edge is raised a little, I then use my fingertips. You would find a Spudger Tool though, makes life a whole lot easier doing this,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYK/ref=sr_1_7?ie=UTF8&qid=1359090938&sr=8-7&keywords=spudger+tool
(It isn't made of metal)
Can't get the guitar pick, or spudger tool in? Move over a little. You are at a Tab/Latch.
Regards,
joecoolvette
Jan 25, 2013 | Toshiba Satellite A205-S5831 Notebook
Toshiba satellite CD door will not open
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
How do i replace the memory in a toshiba satellite A10?
there is a small access panel under the laptop with 2 screws..
Nov 12, 2009 | Toshiba Satellite A10 Notebook
My toshiba a205 s5804 is asking me a bios password
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
Nov 04, 2009 | Toshiba Satellite A215-S4747 Notebook
Splash screen comes up with f2 to enter setup f12 for boot options but freezes will not proceed no farther
First of all if it will let you press F2 and see if you can reset the BIOS to default configurations. Hit F10, save the changes and exit the BIOS.
The computer will restart and hopefully boot to the operating system boot screen.
If it's still freezing on post then remove the battery and the AC power supply. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
Good luck.
Sep 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Upgrading the RAM. Can't find where to put it.
The computer has two memory expansion slots—Slot A and
Slot B. You can install one or two memory modules.
1 Shut down your computer completely using the Shut Down
command.
2 Unplug the computer.
CAUTION: Installing a memory module with the computer’s
power on may damage the computer, the module, or both.
3 Close the display panel and remove any cables you may have
connected.
4 Turn the computer upside down.
5 Locate and remove the screws that hold the cover plate in
place, then remove the cover from the bay.
Removing the memory module cover
CAUTION: Static electricity can damage the memory module.
Before you handle the module, touch a grounded metal
surface to discharge any static electricity you may have built
up.
To avoid damaging the memory module, be careful not to
touch its pin connector on the side you insert into the
computer.
6 Remove the new memory module from its antistatic
packaging.
7 Insert the memory module in the slot and gently press it down
into place.
The clips on either side of the module will click to secure the
module.
Inserting the memory module into the slot
8 Replace the cover plate and the screws.
9 Turn the computer over and restart it.
When you turn on the computer, it automatically recognizes
the additional memory.
Removing a memory module
If you need to remove a memory module:
1 Complete steps 1–6 in “Installing a memory module” to shut
down the computer and open the memory module cover.
2 Pull the clips away from the memory module.
The memory module pops partially out of the slot.
Adding memory
Pulling the clips away from the memory module
3 Carefully remove the module from the slot.
4 Replace the cover plate and screws.
May 15, 2009 | Toshiba Satellite Pro 6100 Notebook
How do I Install my memory in my Toshiba R25-S3503?
ur laptops memory slot is located under the keyboard, u have to carefully remove the thin cover from the top of ur keyboard to reveal the 2 screws, then un screw them to reveal the RAM cover. unscrew the two screws on that to reveal the RAM. be sure to take out ur battery b4 u do this.
Mar 27, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Memory slots?
I found the solution to roger2 and my own problem. The secondary memory add-on slot is on the bottom of the unit, and can be accessed by removing one screw and the slot cover. The other, main memory slot is actually located underneath the keyboard. You should shut down the computer completely, unplug the power plug, and also remove the laptop battery before installing memory. Also, it may void your warranty if you mess around inside of your laptop, so please keep this in mind. You will need to take a very thin flat head screwdriver to gently pry up the panel above the F1-F12 keys. The panel is the entire plastic piece covering the speakers that has the power on, play, stop, ff, rw buttons on it. I used a very thin and flat hair clip that I found laying around to pry up the edges starting from the Pause/Break key moving left towards the ESC key. The screen lid has to be opened all the way for the piece to be completely removed. Once that is taken off, you will see two small screws holding the keyboard in place. Remove these two screws and gently pull out the thin ribbon cable connecting the keyboard to the laptop. The ribbon cable is located directly underneath the spacebar, so move slowly and carefully when removing the keyboard so as not to damage anything. In the center of the exposed area, there is a sort of rectangular metal cover with two screws holding it in place. The one that is about the same size as the slot cover on the other memory slot is the correct one. Remove the screws and open the metal cover. Underneath is the other memory slot. After you install the other memory stick, if you have 4 GB of total RAM, you should know that in 32-bit operating systems, Windows will only be able to use approximately 3.0-3.5GB of RAM. This is because of a limitation of 32 Bit Windows operating systems, and not because of the RAM itself. Only 64-bit operating systems will be able to use all 4 GB. On my system for example, I have the same Toshiba M105-S3041 laptop as you do, running Windows XP Home with two 2 GB sticks, and My Computer properties shows that I have 2.99 GB memory.
Oct 28, 2007 | Compaq Presario Notebook
Toshiba Satellite A205-S4617 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
