Question about Logitech Cordless Desktop S 510
Volume drops On my XP Pro COmputer the volume control slider always starts at zero. Drag it up to max and you get full volume then the slider slides back to zero on its own (The volume decreases as it goes) Using Logitech S510 Cordless Keyboard & Mouse
  • willitonref Mar 19, 2008
    I have solved the problem. It was caused by my Skype Phone. Removing the batteries from the phone and replacing them did the trick
Um, it might be, simple or stupid, thought check the sides of the keyboard, the optional buttons, the volume down, might be stuck, hope it helps
=D
Posted on Mar 16, 2008
Volume control not working
Left and right wires are like the ends of a carbon resistor.
The centre connection is the slider that slides along the carbon resistance.
Spray inside the device,
The centre sliders often loose connection from overuse.
Carefully take apart and clean & put slight tension back on centre slider.
Look to see if carbon track is worn out?
Take the centre wire off the Pot and try it on either end.
One will be full volume the other will be lowest volume.
Read the Ohms value of the Pot (stamped on)
or use a cheap Ohm section of MultiMeter
Note the size of threaded area
Get similar to take it's place
1M 24mm Potentiometer Linear Single Gang Potentiometers Resistors Passive...
Potentiometer Wikipedia the free encyclopedia
Sep 19, 2015 | Audio Players & Recorders
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
I cannot "hear" through the
1. Right-click the speaker icon in the system tray (at the far right of the Windows taskbar).
2. Click Open Volume Controls.
3. Drag the slider in the left column with the mouse to adjust master volume.
4. Drag the slider under the name of the input source to adjust volume for a specific source, such as CD or Wave Out.
Jul 01, 2011 | Computers & Internet
Sound problem
Check taskbar volume control and make sure its max. If you have volume buttons make sure they are maxed. Some laptops are a key combo to increase/decrease volume. Make sure whatever program you are running that the volume slider is all the way up. Go into your control panel and double check your volume settings. Go into your device manager and make sure there are no exclamation points in yellow next to any audio devices or codecs.
Mar 09, 2010 | Toshiba Satellite Pro A210-EZ2203X...
VOLUME TOO LOW ON COMPUTER, HOW DO I SET VOLUME , SO THEY ARE LIGHER
On Vista 64bit version goto control panel>>Hardware and Sound.. under sound click on Manage Audio Devices>> then select your speakers by double clicking on them. In the new box that comes up goto Levels and there are slider bars for all settings - top one is Audio output. Slide this to the right. Mine was set at virtually zero when I plugged my speakers in yesterday.
Mar 29, 2009 | ViewSonic NeoSat SP2104 Computer Speakers
How increase my mic volume
a) to hell with calling india, they are as dumb as bush is.
b) click start > accessories > entertainment > volume controls. when the volume controls open, click on file (drop down menu) then select recording, then click ok. when the recording volume controls come up. select microphone as the default recording device, and make sure the mute box is not checked. slide the volume control slider most of the way up.
c) if you are using yahoo's call-out, run the audio wizard in yahoo messenger before making call.
d) plug your microphone into other 3.5 mm jacks on computer, and use window's sound recorder to see if the computer is picking up audio through the mic.
e) make sure your microphone's mute switch is not turned on (if applicable).
Jun 23, 2008 | Acer Aspire 5610 Notebook
Computers & Internet Logo
184 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
