Question about Bamix De Luxe Hand Mixer
Attachments fall off
Bamix hand mixer. The blades (attachments) keep falling off for no apparent reason
  • Anonymous Oct 07, 2008
    mincer blade attachment falls off frequently, will see if the solution of the spring blade works
  • zraidhan Jan 20, 2009
    ATTACHMENTS FALLING OFF? WHAT TO DO??? i AM NOT ABLE TO TIGHTEN THIS. I HAVE PREVIOUSLY SENT THIS AND IT IS STILL THE SAME PROBLEM
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Posted on Apr 26, 2008
  • jssgrl May 23, 2014
    I did this, though admittedly I used more force than required...how now can I loosen them...?
Unable to remove Bamix mincer attachment, any advice?
Try to gently wiggle it off with needle nosed pliers.
May 07, 2014 | Bamix 391120 mincer blade
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
My bamix attachments keep falling off, tried tightning them as per instruction book to no avail.
II had the same problem but I just kept adjusting it and make sure it fits into the notch, and it works. It a bit annoying, but persevere.
Best wishes
Jan 15, 2012 | Bamix De Luxe Hand Mixer
Attachments falling off Bamix hand mixer. How can I fix this
Tighten the base, carefully with needle nose pliers. I mean the base of the attachments!
Jun 20, 2011 | Bamix De Luxe Hand Mixer
I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok.
Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
Dec 13, 2008 | Bamix De Luxe Hand Mixer
Bamix slowdown - repair service anywhere out there?
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
Aug 11, 2008 | Bamix De Luxe Hand Mixer
Bamix hand mixer seems to be stuck
It says in the manual to soak it in very hot water for 10-20 minutes, then try again. This should free trapped food from the shaft
Oct 31, 2007 | Bamix De Luxe Hand Mixer
Blades
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
Sep 21, 2007 | Bamix Mono Mixer
Bamix De Luxe Hand Mixer Logo
1,281 people viewed this question
Top Bamix Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
