Question about RCA DRC8030N
Tray won't stay closed
I just bought this device a few weeks ago. Earlier this week I decided to burn some of my library onto DVD-R. The tray kicked out my blank disc, declaring it incompatible. I inserted what I thought was a compatible disc only to have the tray come right back out. Even empty, when I close the tray it kicks out immediately. Right now, the tray is sitting open. If I close it, it comes back out.
  • Batster Feb 24, 2008
    Thanks for the advice, guys!
    I may purchase a cleaning disk first, and then check the tray or take it to a service center.
    Sergeant:
    Champion:
  • 317 Answers
Sounds like the track that the tray travels on, is not aligning properly with the locking mechanism. Try oppening the case, and see if the little track is bent of center, as this will cause the problem. If this is not the case, then you might have a defective drive, or something.
Posted on Feb 23, 2008
  • RCA Master
  • 19,396 Answers
The only thing to do on your unit is cleaning the lens. If you do other repair works on it you will lose your warranty
  • Ginko
    Ginko Feb 23, 2008
    Buy a cleaning lens disk, because dirt on the lens can cause your dvd not recognizing the disk inside. Other possible causes may regard the mechanic to load/eject tray, but to do this you need to open your unit. If you bought the dvdr weeks ago, then I assume it is still guaranteed from factory (1 year at least). In this case do not open it. Bring it to an authorized service centre or back to the reseller.
    regards
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
Well my xbox is going hay wire.it blinkes, it makes the noise of when you hit the open button for the tray,it open and closes the tray even when its turned off.i dont think its the red rings of death...
Call the Microsoft support center right away! 1800-4-myxbox. Or visit xbox.com. The warranty will cover it. Send it off and get it back in two weeks free of charge!
Apr 29, 2011 | Microsoft Xbox 360 Console
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
Dvd recorder tray won;t stay in,,, even without the cd or dvd
is this the 360 cause i have never heard of a loose tray, try to take it back to where you bought it.
Jan 10, 2009 | Microsoft Xbox 360 Console
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Help i got this 2 weeks ago and rented cd stuck
Most players have a small hole just below the tray (a little bigger than a pin hole),put a pin in the hole,and the tray should open.
Jul 17, 2008 | Durabrand STS92 System
HL-DT-ST DVDRAM GSA-4163B
*Tangent* After scouring the web looking for a solution to this problem, and I bet you this must be the case and problem for many an optical drive owner, regardless of brand or function (CD-ROM, DVD ROM, CD Writer, DVD Writer, Combo CD Writer / DVD ROM) but after busting my head trying to find the solution, some clever thinking solved the problem, where published articles on the web did not:
LG DVD Writer (HL-DT-ST DVDRAM GSA-4163B) no longer recognizes discs and no longer burns DVDs or CDs
So you have a DVD burner that, for the longest time, properly burnt discs and aided you in archiving absolutely everything that has ever been important in your life, and now, all of a sudden on a whim, the drive no longer recognizes discs (when placing a disc with data on the tray and closing it, Windows Explorer changes the label of the drive from a DVD-RAM Drive to a CD Drive and any efforts to view the contents of the disc produce the mocking-error message "Please insert a disc into drive X:" Furthermore, in Nero Xpress, Nero Burning Rom or Nero SmartStart, the screen inviting you to set burn speed, set a disc volume label, toggle MultiSession Disc or toggle Finalize Disc has a nice bright lit illuminated "Burn" label button inviting you to proceed, but any attempts to place a blank CD-R / DVD-R, DVD+R, DVD+R DL, whatever, into the disc tray and closing it fades out the "Burn" button and never illuminates it again unless the disc in the drive is ejected. This, of course, is irregardless of the disc access light blinking its friendly green accessing-goodness-message and coming to a stop as if everything was peachy upon first closing the disc tray.)
*Tangent* The few times this had occurred to me in the past (with completely different computers and computer configurations save the same DVD Burner drive) I would often start disabling and enabling drives in Windows Device Manager, and if that didn't work, deleting drive drivers in Windows Device Manager followed by rebooting and auto-reinstalling, and if that didn't work, disabling drives in the system's BIOS, and if that didn't work, fiddling with the power supply power leads and IDE interface ribbon cables and jumper settings (from master to slave to cable select) until finally the damn thing would kick in and start operating again. This time around though, nothing was working out. It had been two days of fiddling and the damn drive would not come back to me. I had even undone all the bindings of my drives in my PC case and tried the unit in other machines with the same result, and also tried it in a true MS-DOS environment using a CD ROM driver and MSCDEX with the same result. What this indicated to me was that, contrary to what many of the articles say online, that the problem is not software based like many would lead you to believe, but rather hardware based.
I read so many suggestions and not one of them sounded reasonable, considering that the drive had given me years and volumes of successful burns prior and I had already miraculously brought it back to life before: I was suggested everything from flashing the drive's CMOS to deleting lines in the system registry (regedit) to deleting and installing new ATAPI drivers to installing VERY suspect and dodgy executables that would miraculously fix things, to using different burn programs, to changing IDE Interface Ribbon Cables to changing entire power supplies, and my most hated suggestion of all, "the drive must be broken, but drive's are cheap these days anyway, just buy a new one." FOOLS! After careful elimination of possible causes, I ruled out anything that was software, operating system, or BIOS-slash-motherboard based. Sadly, unlike my pop, I know next to nothing about electronics, so my last hope was that it was a mechanical problem. Since the drive not being able to access standard discs with data on it was a clear indication of the problem, I booted in a MS-DOS environment using a Windows 98 Boot Disk, complete with CD-ROM support (these little f'ers are trusty when you get into trouble.) I called up the drive letter for my quote-unquote defective DVD Writer, placed the data disc in the drive, closed the tray, ran a simple DIR command and waited for the "device not ready" message. Once that came up (as expected), I ejected the disc tray, walked to my Grand Mother's sewing room, got a good ol sewing pin (no doubt created before the concept of home computers were even fathomable) closed the disc tray once again, ran the DIR command again, but this time, while the disc was trying to be accessed, I pushed the pin into the little emergency tray release hole, forcing the tray to eject just enough to grab onto with my fingernails. I then simply pressed the standard electronic disc eject button again, invoking a close of the tray, and low and behold, the directory contents of the disc came up. I didn't even have to run additional tests, I knew right then and there that the problem was a mechanical one with the closing of the drive (perhaps the gears were no longer coming into the proper position to place the motor hub onto the hole of the disc or the laser eye became stuck in a position that did not favour starting on the first track of the disc...who knows) Bottom line is, the thing now works as it always did, as intended.
QUICK SET OF STEPS TO REPRODUCE:
Pre-Requisits: Authentically pressed data disc that you do not care if it gets damaged (like an old outdated driver disc, AOL access disc, etc.) and a pin long and thin enough to get significant travel into the emergency release eject hole located below the disc tray (safety pins are a good choice, while thumbtacks and nails are not.)
1 - Boot PC with no disc in the troublesome drive
2 - Within operating system environment, open disc tray, place useless data disc on tray BUT DO NOT CLOSE TRAY
3 - Access a read function of the troublesome drive (in MS-DOS, navigate to the drive letter assigned, close tray with disc and type DIR or in Windows, double click My Computer, double click the troublesome drive's letter until the "please insert disc into drive X:" message comes up, and then close the tray with the disc
4 - While the disc is attempting to be accessed, in a straight manner and with pressure, push the pin into the emergency tray release eject hole until the tray pushes out physically
5 - Close the tray by means of the standard electronic eject button on the drive
-Video Game Junkie
Apr 07, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
CD tray opens and won't stay closed for burning
Sounds like an issue with the contact behind the button on the drive. How old is the drive? Replacements are cheap these days.
Sep 04, 2006 | HP (dw381a) CD-RW/DVD-ROM (Combo) Burner
RCA DRC8030N Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
