Canon PIXMA  MP160 All-In-One InkJet Printer
Problem for Canon PIXMA MP160 All-In-One InkJet Printer
Canon mp160 printer E5 flashing error?
By bigfries on Feb 23, 2008
any tricks to overcome this without buying new cartridges?
Same Problem
Jan 17, 2009
-   my mp160 has error code e5, I change inks, driver, it still does not work, why? how to fix it -   Guest
Jul 30, 2008
-   HI!ANYBUDY CAN HELP? MY CANON MP160 PRINTER HAS" E5 "FLASHING ERROR PROBLEM.
HELPLESS BUDY-   Guest
May 24, 2008
-   i already tried that one but nothing hapen, pls help. . . . -   Guest
Best Solution
posted on Feb 23, 2008
Very Helpful)
clusterfx
Rank: Guru
Rating: 92%, 153 votes
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jun 28, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It worked great fix
Thank you
OCA
Solution #3
posted on Mar 16, 2009
Somewhat Helpful)
ksdi
Rank: Wiz
Rating: 82%, 29 votes
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
266
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP160 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP160 All-In-One
Do you recommend Canon PIXMA MP160 All-In-One InkJet Printer?
Answer
Answer
Printer displays Error Code 4 and 2 when ink cartridges are replaced
Answer
My canon mp160 show alarm & dose not work pls solve my problem?
Answer
MP160. Will not print. Error message, remove paper jam and push start button. there is no jam and... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
