Question about Intel D865GBF Motherboard
Wiring up my motherboard ,, conections its my dauthers pc ,, and a friend said he could help ,, and left her,, holding ,, abox of junk new ,, im thinking i can help her put it back togther with your help ..looking to find a manal scmatic.. if i can ,,
    Master:
  • 474 Answers
Those are hard to find for a mother board unless you know the model number and manufacturer, then you can try going to there web site and downloading it. It all bassically the same except when it comes to the little black Pins you have to plug in for the power switch and the HDD light and the USB ports. Look closely on the board, sometimes there labeled ( PWR SWCH = Power switch, HDD = Hard drive Light in front of case, REST SWTC = reset switch, + and - for the USB pins, generally solid black is Positive.) Now this is relative but not exact, some boards abbreviate or show them differently on the bopard, but look for a group of metal pins sticking up and see if they say what your looking for.
You can try guessing till you get it right, but it takes a while, it shouldnt hurt the board if you wire it wrong, now a days they are built with protection devices to keep you from fryinh anything, but still excersize caution. Everything else on the board is easy, most ribbons and connectors only fit where there supposed to go.
Posted on Feb 23, 2008
Switch wiring
E-Machines Branded PCs Are Junk!
Here Is My Advice: Buy A New PC With An Intel Pentium Prossor!
Nov 17, 2014 | E-Machines T2642 PC Desktop
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
I turn the notebook on and i have power but nothing comes up on the screen. it is a hp pavillion dv4000 im not very educated on computers but if u guide me through im sure i can do it.......thans for the...
Hi There,
Your laptop needs some troubleshooting and here's the fastest (and free) way to locate your issue. Get to a friend's place (or at home) where there's a regular desktop computer monitor and connect your laptop to it. Look up at the top row of "F" keys (1 thru 12) and find the one that looks like it has to do with a monitor. With your laptop connected to the external monitor, press the "fn" key in the lower left of keyboard and hold it doen while your press the monitor transfer F key above.
If your laptop's normal display shows on the big monitor, then you just have a bad sceen that needs replacement. If all is dark on both, then your video card inside the laptop has faild and a new motherboard is needed.
Kind Regards,
TheSelkie
Oct 09, 2010 | HP Pavilion dv4000 Notebook
I dont know my WEP Key of my network im on. it is the wireless network in my house im connected to on this laptop
Press & hold the reset button on the router. It's very tiny & you may need a paper clip to do it. They're usually located near the power jack. Hold it in until all the lights go out,then release it. This clears the wep key or password. Now you can get on the network. You'll need to use a pc that's wired to the router to put a new wep key in & password,unless you just want to stay unsecured.
May 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I formated my pc P4 model number d330m/p2 now i,m having problems i media player in not functioning, there is no sound how do i download the sounder drivers
hi im josh in cebu phils.may i help you? Friend after installing new o.s or after formating the media didn't work because no media driver is installed like sound, or video,etc. so yes you need to download the driver of that motherboard inorder to make the media player works.or if you have the motherboard driver.install it the media driver is also built on it. thats all my friend good luck hope i helped you.
Feb 25, 2009 | Computers & Internet
Download of new XP windows stuck in 16 bit resolution screen
sorry, but learn how to install xp pro. Skip the internet connection. Plug the plug. Install internet AFTER the xp install. let it ride
Jan 25, 2009 | Intel Motherboard
Mt3422 display
Bad motherboard.  A new one is about $300 but it eventually will fail again as I am currently researching this issue and seeing many complaints of this nature.  People have replaced the motherboard many times and came across the same issue.  I am working in one for a friend am going to recommend he junk it.
Aug 28, 2008 | Gateway 7405GX Notebook
Gateway 507GR
I can already tell this isn't going to be an easy one. Let's try a few more things.
  1. Unplug the power supply from everything inside the PC. Leave it plugged into the AC cord. On the main motherboard (ATX) power connector, find the pin that goes to the green wire. Use a modified paperclip to short that pin to the next-door pin that should have a black wire. This should cause the power supply to turn on and you should hear its internal fan spin up. If not, this could be a sign the new power supply is also dead.
  2. Plug the power supply into only the motherboard and AC cord. Remove all unnecessary PCI cards and peripherals. Also, if the system has multiple RAM modules, remove all but one. This should leave the power supply, motherboard, video card (if it's not built in), CPU, and RAM as the only items connected. Power up the system and see if anything acts differently.
  3. If there are multiple RAM modules, try every different combination of modules and slots.
  4. I will ask this only because I've done it myself. In the swap between the old and new motherboards, did you verify there were no extra mounting stand-offs that might be touching something on the bottom side of the motherboard? If old and new motherboards are the exact same model, this shouldn't be an issue, but you never know.
  5. Verify there are no jumpers on the new motherboard that might need to be set for the front side bus, memory speed, etc.
  6. Ask your friends, family, and neighbors if anyone has a Pentium 4 in an LGA775 package that you could "borrow" to verify it's not your CPU causing the troubles.
Mar 05, 2008 | Gateway 507GR PC Desktop
Xbox live
Your router is not LIVE compatible.
Get a Live compatible router.
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Feb 24, 2008 | Zonet (zfs3008)
Intel D865GBF Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
