Question about Sony KP-57WV700 57" Rear Projection HDTV
No picture or sound
TV has power but no picture at all and no sound
  • 1 more comment
  • bekelly Feb 23, 2008
    42" Apex tv...the power comes on but it just shows a blue screen with lines going thru it, no sound and no picture.
  • bjones79 Feb 24, 2008
    this TV is a 72cm Loewe Calida Super Flatline. absolutely no picture at all.
  • MICHAEL MULLINS May 11, 2010
    Make sure you a signal, turn volume up, change inputs until you get audio. Got sound, still blue with retrace lines? Possible shorted picture tube or blue crt drive circuit.
    Problem Solver:
  • 5 Answers
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Posted on Apr 15, 2008
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
LCD Samsung tv no picture no sound
Try to unplug set and a box if used from power for several minutes and then power back to see if a reboot will help or not.
Dec 10, 2012 | Televison & Video
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
Sony KP-57WV700 57" Rear Projection HDTV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
