Question about Apple MacBook Pro Notebook
Mac laptop displays minimum brightness
My mac laptop display defaults[?] to minimum brightness (nearly black screen) at start up.  This problem is random, as far as I can determine.
Shining a bright light on the screen allows for mouse pointer tracking, which then allows for the following fix: System Preferences > Display > Maximum Brightness.
Why does my mac laptop randomly start up with a dark screen?
  • skleitz Mar 04, 2008
    Thanks, I think I fixed the problem by changing the System Settings to not dim the screen to minimum brightness after five minutes (or when there's low battery power).  I set these for three hours, added a screen saver option, & haven't had the problem since.
    Problem Solver:
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Posted on Feb 23, 2008
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
Dim screen on Mac A1013
What os are running. Check in the preference pane under display if auto brightness is enabled if yes doable an increase brightness slider.
Feb 13, 2014 | Apple PowerBook G4 Mac Notebook
Screen dim lighten
On your Mac...
Click on the Apple icon at the top left of your screen.
Then select System Preferences.
Then select the DISPLAYS icon.
In the displays window, you will should see a Brightness slide bar. Make sure that slider bar is all the way to the right. The the slider bar is already to the right side, then it might be a hardware issue with your Mac. =(
Feb 06, 2014 | Apple Computers & Internet
Black screen
Have you zapped the p-ram? Hold Apple, Option, P and R keys when you hear the chime. Wait for four more chimes and release.
Try "detect displays" from display preferences. In system preferences, displays, be sure brightness control is turned up.
Feb 11, 2013 | Apple Mac Pro A1186 Desktop
Display is too Dark to work with but brightness lever up to max.
Apparently the backlight for your display is failing. You'll most likely have to have the top half of the macbook replaced per Apple usual service standards.
Feb 15, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
The screen on my apple ibook laptop is black, whats wrong with it?
First make sure your screen brightness is not turned down. If not, and the computer can still turn on, chances are it's the logic board or display that has gone out. Your computer will need to be repaired by a specialist.
Feb 15, 2011 | Apple iBook Mac Notebook
Laptop will not display screen although is turned on.....
I assume you are saying the screen is totally black, not blue. If it is totally black there can be a large number of causes. It is hard to give one simple answer. It could relate to the brighteness of the screen, the display, the logic board, the graphics card or even a problem relating to updating Apple firmware, You could try some simple things first.1) If the lighting on your computer is accidentally turned all the way down, your screen will be black! To turn the brighteness up, push F2 on the top of your keyboard and click until the lighting improves and you see the screen. If your display stays black it could be an indication that you just need a new Display. They do wear out. 2) Another thing to try is to start the computer in Safe mode. http://support.apple.com/kb/HT1564?viewlocale=en_US As you push the power button hold the shift key down. This can sometimes help resolve issues relating to startups. Also, if your screen stops being black it is an indication there is nothing wrong with your display. 3) You could try resetting the PRAM http://support.apple.com/kb/ht1379, This can also help with a startup issue. 4) Some specific models of Macbook Pro computors have issues caused by the NVIDIA graphics card, which Apple knows about and apparently will repair, possibly free of charge. My suggestion if none of this helps is to take it to a Genius bar at an Apple store for them to troubleshoot. That, in itself, costs nothing. Other suggestion search with google for further answers from other Mac owners!
Jul 14, 2010 | Apple MacBook Mac Notebook
Why video quality in mac is not good it seems
Try going to your System Preferences which is in your Utilities folder located in your applications folder. In system preferences, click on the button called "Displays"... from there, adjust your brightness (turn it up).
Also, if video quality is bad in Quicktime - open quicktime and go to Window tab located at the top right near the help tab. Then click on Show AV Controls. You can adjust brightness from there.
Also, within the Displays button, try calibrating your monitor by following the simple instructions.
Apr 15, 2010 | Apple Mac OS X 10.4
The screen suddenly went black while connected to an electrical outlet. Nothing works.
Three immediate possibilities in order of expense:
1) Make sure the brightness is on. Press the F2 key.
2) Screen backlight could be blown out, especially if you can hear the disk seeking, fans, etc. even though the screen is black. Connect your Mac to an external display or TV using the appropriate adapters. If you get an image, you need a new backlight or LCD panel.
3) Entire machine is plotz, especially if you hear absolutely no chimes, disk movement, optical reset, fans, etc. This may indicate a power board or logic board issue.
Sep 30, 2009 | Apple PowerBook G4 Mac Notebook
Screen intensity goes to minimum.
Your G4 is attempting to save its display from total breakdown by lowering its intensity to minimum.
Mar 22, 2009 | Apple iBook G4 Mac Notebook
Apple MacBook Pro Notebook Logo
730 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
