Question about HP OfficeJet 6210 All-In-One InkJet Printer
"Scanner Failure" message
When trying to copy or scan, control panel message is "Scanner Failure - power down and restart".  And simultaneously an error message on my computer screen pops up, which says "The automatic document feeder is empty".  This happens when attempting to copy or scan from the glass.
Curiously, when attempting to copy using the automatic document feeder, it works!
Printing from the computer works fine.
Anyone have any ideas???
  • 2 more comments
  • Anonymous Feb 23, 2008
    My OS 10.5.2   macbook will print on the 6210   but it does not scan.
    How do I install scan hardware or does this HP product only work with old systems?
    Lynn
  • Paul9 Feb 23, 2008
    I downloaded and installed HP_Installer_OJ6200_v9.7.dmg 1/1 (170.03M).
    Still having the same problem - scanner problem.
    Any other suggestions?
  • fatherkral Apr 25, 2008
    I have an HP OfficeJet 6210 and when I scan directly from the glass I get and error "Scanner Failure, Power Off and ON". If I scan with the lid down and use the feeder, all is well. Any ideas? Thanks so much!
    By the way, I went through all the HP reccommended steps to correct this problem.
  • tlbaaske Oct 03, 2008
    I am trying to scan from the glass flat bed. When I enter the HP Image Zone to scan, the scanner starts to move then it stops with an error "Scanner error ... turn off and on again". I have done this several times and it continues to come up with the same error.
    Genius:
  • 3,587 Answers
Sure..new drivers might make this happier..
check your warranty here for FREE
Posted on Feb 23, 2008
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Scanner failure message
the main system is faulty same thing happened to me.
Aug 14, 2009 | HP 7210 OfficeJet All-In-One Printer
Scanner failure
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
call in to hp at 1800-474-6836 and since this is a hardware issue directly tell the agent you would like an upgrade if you decide to get it.
It will have a 50% discount on the upgrade printer for you with hardware and software covered by a one year warranty which you can extend upto 3 years on the spot
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 750xi scanner failure
Try the hp site:
I was having the same problem but ended up being able to scan using Windows Photo Gallery and my HP 750xi. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&lang=en&product=58917#Workaround
Dec 04, 2008 | Office Equipment & Supplies
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
1.
2.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
5.
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
818 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
