Panasonic Projection TV
The sound goes out on my TV model number PT-51G54A. It is a 2000 model. I can touch the back of the tv and the sound will come back but it goes out again randomly. The picture is very good and I want to keep my tv.
  • 927 Answers
If you are using your TV's internal speakers, then you have a loose connection inside your TV more than likely on your audio output IC. Re solder all connections on your audio output IC's. To locate your IC, trace your speaker wire back to the circuit board.
Posted on Feb 23, 2008
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Picture goes away on my DLP TV
that is an overheating problem. With the TV unpluged clean and or vacuum the internal tubes. Not the lamp though. Do not touch the lamp as any oils on your hands will cause a hot spot and the expensive lamp will fail.
Dec 08, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
