Question about Philips 50P8341 50" Rear Projection Television
50p8341 on-screen menu
How do I adjust the on-screen menu position its not centered the bottom is cut off,the whole menu has to be moved up,I cant see all menu options
  • Anonymous Mar 01, 2008
05/09/08
I called the Philips help number (1-888-PHILIPS) and the tech had me turn off the tv and then unplug it from the outlet, wait 1 minute, then plug it back into the outlet, then turn the tv back on. It reset the menu memory and it is now back in the middle of the screen where it belongs.
Posted on May 10, 2008
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
I am having a hard time adjusting the color and focus on my Phillips 50p8341. Can you help?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 12, 2009 | Philips 50P8341 50" Rear Projection...
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
JVC av-56pw30 Picture Adjustment
Sounds like you have a convergence problem and the set will require repair. This repair will run somewhere around $400 if you have a good company complete the repair for you.
If you are interested in doing this repair yourself you will need to be able to use a meter and solder VERY well.
If you have more questions please email me.
Thank you,
Tim Nolan
Experttv@comcast.net
Oct 11, 2008 | Televison & Video
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Sharp 42In
Go to the Menu
Select Setup
Select Position
Select V-POS and move the slider to the right.
If you do this when the score scroll bar is on the bottom of the screen you can make the adjustment to suit your needs.
Sep 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Philips 50P8341 50" Rear Projection Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
