Question about Canon PIXMA iP4300 InkJet Photo Printer
Its not printing in black
Hi!
I have a Canon IP4300 and new black cartridges however, when i print in black the printer seems to be printing but the when it finish the paper has nothing on it. I can print in color without a problem but not in black.
  • 2 more comments
  • 52daveo May 05, 2008
    I put in a brand new black cartridge and it goes through the motions of printing but nothing actually prints on the page ... The red light stays on on the new cartridge
  • Fredap May 16, 2008
    exactly the same problem with anCanon IP4300 ink jet printer: nothing in B&W, and ok with colors
  • Kurtashak May 21, 2008
    exactly the same problem! i bought a new cartridge even tho the previous one was half full. called canon they said there is smt. wrong with the printhead. The weird thing is that if you change the software to photo paper, then it does print, but there is no draft print option.
  • beefa May 29, 2008
    I have canon ip4300 but will not print pgbk black..I have done all the necessary print head cleans but still will not print..even in nozzle check it will not show printing in PGBK..is there any way of manually taking out print heads and cleaning..i've heard that windex does work..is that a problem or do i have to get a new print head..will the cleaning unit being advertised on ebay work i live in adelaide Australia
I had the same problem. Too early to know whether this will help in the long run, but I can print in black if I select manual instead of automatic. The print quality is fine which would suggest there is nothing wrong with the head.
Posted on Jun 17, 2008
  • 148 Answers
You need to replace your new cartrige. Im sure it has warranty
Posted on Mar 21, 2008
Go to the Canon dowloads website and get the driver for you OS. Re-installing it fixed this problem for me. The changing to Photo resolution then trying a print works to prove the cartridge is fine but the permanent solution is to reinstall the drivers.
Posted on Jun 19, 2008
My printer will not print black ! it prints every other colour, but not black. I changed the ink cartridge and i cleaned the heads. What else can i do? It has been a loyal printer until today. please
Hi you mentioned that the Ink is new and that you have cleaned the ink heads, have you checked if the silicon Film for the ink cartridge contact was removed?
if that film is not removed cleaning the printer head will still not detect the ink cartridge for the Black on your printer.
Turn your printer OFF and remove all your print cartridges then install all of them again one at a time then turn the printer back ON, see if all the ink cartridges are now detected and if the Black will now print.
Also if you can
Nov 10, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have a Canon Pixma ip4300. I replaced the 5 PGBK (the large non-photo black) cartridge and I went to print. A piece of paper got jammed, so I pulled that out and since then, that brand new cartridge...
Hi I think you may find a very small bit of paper may jammed under the print head, try removing the cartridge and have a close inspection, it only takes a tiny piece to cause the problem cheers Terry
Feb 26, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Having problem with my Canon iP4300 printer which is printing colour but not printing in black.....Please help me.
clean the electrical contacts of the black ink cartridge using a lint free cloth and also the inside of the printer.
this you can do, after unplugging the power cord.
now, plug the power and then insert the ink cartridge. And then check by doing a standalone copy.
If the copy is also blank, try with a new set of blank ink cartrdige.
Aug 12, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Feb 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Black text printing not using large cartridge
Change your setting to plain paper and normal quality.
This printer uses the small black for photos and high qau;ity papers.
Do this and you should be good to go.
Jun 28, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Two black cartridges required??
The printer does recognize 2 different catridges. My understanding is that the smaller is specific to photos,
but the larger is used for everyday text and pages.
I would get the cartridge and then wait to see if the printer
won't print photos when small cardtridge is out. If it does
print, pictures may not be good enough for you.
Apr 18, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
210 people viewed this question
old marine
old marine
