Question about Palm Treo 500 Centro
Palm Centro I've only had my palm since the end of Nov and now it won't power up. The red light shows when it's hooked up to the AC adapter, but when removed, there is no light, there is nothing. Whats the warranty on this?
  • 21 more comments
  • Anonymous Mar 11, 2008
    I also got my red one in Nov. and have exactly the same problem you described. Help!
  • Anonymous May 14, 2008
    If you hold down the end button for a few seconds it will be ok. That's the stand by mode.
  • BrendaDz May 15, 2008
    I am having the same problem. Mine Red Centro tried to hotsync, turned off, and will not turn on. This is the second time. The first time a soft reset fixed the problem now nothing seems to be working. The little red light when you plug it in turns on, my computer recognizes it but the Centro itself is not doing anything.....Have only had it for a couple of months. HELP!!!!
  • zippersabrat Jul 14, 2008
    Mine is the black one from Sprint..same problem. Nothing seems to make it turn on. It worked fine earlier in the day then when I called voice mail I could only hear via speaker. I returned the call but could only listen via speaker and the other party could not hear me at all. I took out the battery and it went into a loop of trying to hotsync (sans cable). I was able to get it to hotsync and then it started working. The only issue at that time was that the circle Palm button did not work so I pulled the battery again. Now it is been off for 6.5 hours and nothing works. The charging light comes on when it is plugged in but the USB cable does nothing and the screen remains black.
  • Anonymous Aug 03, 2008
    mine is from verizon and everything is working great its just the red light is ALWAYS on and idk if its damagin the phone or not.
  • BreAnna7291 Aug 09, 2008
    ihave a pink centro the screen is blank it will not show anything. If it is hooked up to the charger the red light will come on but no light on the screen.
  • y3p3v3 Sep 04, 2008
    I have this same problem it started with the automatic hot sinc and it freezed the phone.. then i removed the batery and when i put it back the red light turn on and my palm dosent turn on it only haves the red light
  • amanpdkid Dec 07, 2008
    I am having the same exact problem. I have tried hard resetting it, charging it for a few hours, and leaving the battery out of the centro for a few hours. Nothing seems to work. Mine is still within the 90 warranty, do you think i should take it back?
  • Anonymous Dec 12, 2008
    my palm centro started that automatic hot sync and it will not turn on now. it has the red light when i plugged it into the charger and removed the battery several times. PLEASE HELP.
  • Anonymous Dec 14, 2008
    my son's palm centro doesn't turn on. The red light is stays on and I can't turn it off. Any clue how to fix?
  • Anonymous Dec 16, 2008
    My red palm centro does the same thing! I try to make it turn on and it wont. I took it to sprint and they told me it was just dead, although i know it was not.
  • mvivanz Dec 21, 2008
    My battery died. I am recharging it but the on/off button doesn't seem to work but the green light is on and blinking.
  • Anonymous Jan 15, 2009
    the phone wont turn on. it froze and went off and the red light is ther when the AC is in the phone but when removed it tunes off.
  • elizabeth dixon Jan 20, 2009
    i have the same problem, my centro just started hot syncing out of the blue and i tried to reset it by takeing the battery out and now it wont power up, only a red light will come on. please help me!!! i've only had it since the end of nov.
    i ve had my plam for only @ months and it wont power up anymore! what do i do??
  • meganhigdon Jan 25, 2009
    My centro won't power up unless it is plugged in.  I've only had it since July.
  • Anonymous Jan 27, 2009
    My centro won't power up unless plugged into the ac adapter or my car adapter ... had since last April and I'm bringing it back for repair. I see other people have had the same issue, did anyone find out why it started doing this? It happened out of the blue with me ...
  • Anonymous Feb 10, 2009
    My phone will not charge i left it on the charger for a day and it still didnt charge
  • piggaroo916 Mar 22, 2009
    palm centro (sprint) forcing hotsync even when not plugged into a pc. It keeps trying to hotsync and wont let me do anything else. It ONLY works when actually hotsynced which means my phone is on a leash.
    sometimes it wont even turn back on if turned off no matter what i do. argh! Sprint said it was water damage. i dont think so.
  • RazrRad Mar 22, 2009
    i received a text message and when i pressed the palm button to unlock the screen it shut off and it wont turn on no matter what please help
    Contact: radovanrules@yahoo.com
    HELP
  • brenda14 Mar 23, 2009
    my phone turns complety blak and thres only a lil red light
    it wint light me do anything becuz itz complety black !!! sum1 plz pzl help i only had my phoone 4 1 day plz plz !!!!!!! im despret
  • jacsica Mar 30, 2009
    my centro kept trying to hook up to hotsync and when i got it off of that screen, the keypad wouldn't work but the touchscreen would so i took out the battery and put it back in and now it won't turn on at all. when plugged into the charger, it shows the red light but it still has yet to turn green. when i plug it into the computer, the computer doesn't register it as being plugged in. this is like my 3rd replacement phone and i'm getting a little sick of it...
  • lorsban Apr 20, 2009
    after getting splashed (not drenched) with water this exact same thing happened to me.
    looks like the only thing left is a trip to the service department...
My daughter's phone had the same issue of the red charging light remaining on constantly and the phone not booting up....
I something similar happen to a PSP console too.
If you have a Sandisk or other type of expandable data card in the phone... remove it.
Remove the battery for about a minute and put the batter back in...
The data card is probably corrupt and needs to be reformatted.
I did this and the phone booted with no problems.
Just like my PSP.
Hope this Helps....
Posted on Jan 27, 2010
The red light is usually on because ur "phone" is off but the "device" is on, u have to hold down the power button to turn the "phone" back on also u cannot turn the device completely off unless fully dead or battery is out
Posted on Sep 18, 2008
Try takinga Q tip and dipping it in rubbing alcohol, and clean the receptors.
Posted on Sep 08, 2010
My phone is doing the exact same thing. The red light comes on. Then nothing else does... What to do what to do. It isn't water damage. I have left the battery out for several days. and Tried to put it back in... WTF is up with this phone... Seems I'm not the only one with this problem!
Posted on Jul 01, 2010
Alright, this isnt a solution, but a question, Ive taken my battery out all night and put it back in and still onlt the red light turns on, nothig else.
Ive also tryed a different battery.
I have having a problem where it kept trying to sinc with the computer and wouddnt let me do anything else, I took thebattery out and put it back in and nothing would turn on, did it a few more times, and it finally did.
It worked normal for awhile then it stopped letting me use everything except the touchscreen.
Now, I took the battery out for awhile then thats when I came to the situation Im at now, only the red light turns on.
Posted on May 05, 2010
I would like to know more about the meaning of the status icons on the Palm Centro?
Posted on Mar 04, 2008
Mine is the samen, i think.
The red light will stay on forever, and it says that the phone is off, but the devicce is on. I cant make calls, get on internet, or recieve text.
I usually do a soft reset (take the battery out and put it back in. It works for a while then, but then will go back to the phone being "off"
Posted on Mar 21, 2008
    Problem Solver:
  • 4 Answers
One suggestion I have is if someone can post a link to the original ROM from the carrier - Sprint, ATT, Verizon. then I would suggest flashing the ROM since it seems like a software issue. I was able to flash my ROM with the updade (1.7) provided by Sprint. It took me a while since my centro only turned on a few times when it reset, but with the update it still did the same force hotsync issue.
I think if I was able to install a new ROM completely, like reinstalling Windows for PC it might work fine.
Posted on Mar 22, 2009
How do I increase the signal strength of my Palm Centro?
The bars show relative signal strength.
If the Motorola is on the same provider, it is the Palm smartphone that is the fault. It may just be you got a less than sensitive one. You should probably contact Palm and see if there is anything they can do short of exchanging it, otherwise exchange it and keep exchanging them until you get one that works. In mass production- these things happen.
If the Motorola is with a different carrier, that may be the difference- they are line of sight devices and the provider you have for the Palm may not have an antenna in your vicinity pointed in the correct direction for you. Which means complaining to the carrier since you know the external antenna works, but the Palm does not.
Jul 07, 2012 | Palm Centro 690 Blue Smartphone for...
My PALM Centro will not charge i have it plugged in via USB my AC charger quit working months ago and i threw it away. Therefore i have it plugged in via USB and the LED at the top it green but barley on...
Hello salvidor72,
It's more effective to use a charger than the usb adapter. The wirelessemporium.com web site has a nice deal on a Palm Centro PDA Phone Home/Travel Charger:
http://www.wirelessemporium.com/p-16501-Palm-Centro-PDA-Phone-Home-Travel-Charger.asp?refer=bizrate
You may also do a google search for palm centro charger. I hope this helps.
Have a great day, martyshaw152
Feb 22, 2011 | Palm Treo 500 Centro
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
My palm centro keyboard and other buttons randomly stopped workig
Hello hyuuga4567,
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option +
Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Sprint Palm Centro Smartphone
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
• Select Prefs
• Select Keyguard.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Palm centro screen blank without droping it.
check the flex connectter for the screen make sure its in there all the way on the mother board.
Dec 16, 2009 | AT&T Palm Centro Cell Phone - White
Palm Centro will not charge. Red lite comes on
Jim,this shows that the charger and the charging circuit are fine and kicking. Only the battery is debatable. If an old battery then it has gone. even not so old battery could be the culprit. so, replace it.
Sep 08, 2009 | Palm Cell Phones
Hard reset for a Cetnro Palm phone
take your battery out, then hold your on/off button WHILE putting your battery back in
Dec 09, 2007 | Palm Treo 500 Centro
Palm Treo 500 Centro Logo
9,865 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
