Convergence problem on RCA HDTV
My tv is about 1.5 years old and has recently started unaligning randomly while it is on. What i mean is that red, green, and blue are all off by about 3 inches and form 3 lines accross the screen. Turning off the tv and letting it sit sometimes fixes it, and sometimes it just fixes by itself. It is connected via the hdmi port and now also to the component connection with no help. From what i have read it could be the convergence chip? I was wondering if anybody believes this to be so and where i could get a chip number for it and/or any other parts that might be bad.
  • 1 more comment
  • Andrew2323 Feb 24, 2008
    The model number is R52WH77. Chassis number is ITC222A. mfg. June '06. Thanks for your help
  • boomboom370 Apr 01, 2008
    I HAVE A SIMILAR PROBLEM WITH ITC222A , IT IS BOWED AT THE TOP AND BOTTOM OF PIX.
    CHANGED THE CONVERGENCE MODULE THAT I HAD OUTTA ANOTHER SET BUT ITS STILL THE SAME.
  • STEVEO32 Jul 02, 2008
    I HAVE THE SAME PROBLEM WITH THE SAME #'S. IS IT EASY TO FIX? STEVEO32
  • 8,617 Answers
What is the model and chassis number for your set? Te chassis number is most important to diagnose a RCA set. Please post the chassis number located on the rear panel of the set.
Posted on Feb 23, 2008
  • Sonny Berry
    Sonny Berry Feb 24, 2008
    Due to the fact that it fixes itself at times leads me to believe the ICs themselves probably just need soldering. I would try that first before replacing the ICs. ust be careful not to bidge any of the pins with solder while resoldering. Check your work with a magnifying glass before you power it up.Let me know if yo still need the IC numbers.
I have an RCA L32HD31R LCD tv that has: - Double imaging - Red, blue and green are unaligned - 2/3 of the screen is has a background that flickers random colors (usually purple to turquoise) - Lines and...
I have one doing the same thing. I noticed capacitors on the power supply were bulged slightly but everything else looked fair but dirty. I blew it out with compressed air and there seemed to be a change but I am still stuck in the same place myself....
Jan 30, 2011 | RCA L32HD31 32 in. LCD HDTV
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Colors not aligned
convergence circuit. prob. need tech
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Rca 52" projection tv...d52w20
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
