Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Brushes won't rotate during floor cleaning.
  • 5 more comments
  • Uffda PaPa Feb 27, 2008
    LITTLE OVER YEAR OLD-- NOW NO WARRENTY AND HARDLY USED SHAMPOOER- EXCEPT FOR OCCASSIONAL TOUCH UP TIMES--- RELUCTANT TO GET A NEW ONE, AS OUR OLD ONE WENT 3-4 YEARS WITHOUT GIVING OUT ON US.--- GUESS NEW, IS NOT NECASSARILY BETTER!!! ----THANK YOU, FOR SUGGESTIONS TO PA PA. DISAPPOINTED--- UFFDA MAMA
    LizDahl----Thank you for support and information I 'll try finding shampooer you suggested on the internet, to locate company. Ma Ma says thank-you tooo. uffda pa pa
  • hereiiz3 Aug 05, 2008
    I have only had my hoover since the end of may and have only used it 3 times. My husband was the last to use it, however; he had only used the hand tool for my stairs. But I went to use it today and the brushes wont spin. I even tried to spin them manually and they wouldnt budge. Any suggestions?
  • Anonymous Aug 20, 2008
    I have the same problem. I recieved my Hoover Steam Vac. as a Mothers Day gift in may, used it once and 3 months later tried to use it agian and the brushes would not spin.
  • karrun Aug 22, 2008
    I am having the same problem with my steam vac, BUT one thing that I noticed is that there is plenty of suction in the intake. Wouldn't that suggest that the turbine is working fine? Maybe a belt? But I can't find the belt, just a tan plastic kinda Y shaped cover that I can't figure out how to remove. Help anyone?
  • jeanstigers
    jeanstigers Jun 22, 2013
    I haven't had my Hoover steam Vac not even a yr. It has cause me more problems. First it was the nozzle was cracked & hoover sent me a new one, but U can't remove the old nozzle, so I took it to a repair shop & they wouldn't touch it because evertime they tried to remove it , it broke & they had to replace the carpet cleaner. Now they brushes won't rotate, I did everthing the manuel & no brushes rotate. It is to worse s carpet cleaner & have ever bought, too many problems!!!
  • Neil Edge
    Neil Edge Sep 16, 2013
    Ours the switch got stuck in the off position and would not budge. I finally had to take the tanks off the unit and lay the handle back. Using a small screwdriver as a pry bar I stuck the driver into the area where the switch was and felt for the mechanism. With both the screwdriver and the actual switch I was able to finally get it to move into the HI position where now it is stuck. At least it cleans floors and the brushes stop spinning when you put the handle up and it's in Tools mode. This is the 2nd hoover steamvac I've owned and the other one the brushes stopped completely as you guys mentioned. Once this unit dies I will make sure to purchase a different product next time, Hoover's had 2 shots with me and that's more than enough.
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Posted on Apr 03, 2009
  • scottyswifey Apr 03, 2009
    And no there are no belts in the steam vac
I have the Hoover F7210-900 and experienced the same problem of brushes not turning. It started less than a year after purchase with moderate spot use (keeping up after my new puppy). Since I procrastinated and missed the warrantee window I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Now if I can only figure out how to open up the front nozzle so that I can clean out all the dirty carpet fibers!
Posted on Nov 29, 2008
I need help putting the turbine back together, it was froze, i took 2 gears apart and oiled well and loosened it up but cant seem to put the gears back correctly my email is yankee4ever71@verizon.net thanks
Posted on Dec 11, 2009
Thanks for all the tips....I am also having the same issue. I am going to work on it tomorrow and I will post the results! Thanks for the step by step info scotty's wife.
Posted on Sep 20, 2009
  • 75 Answers
Most likely a bad wire or thee motor may have blown for that part of the machine.
Posted on Feb 23, 2008
  • Liz Dahl
    Liz Dahl Feb 27, 2008
    Well if you do end up with a new one, think Aerus FloorPro.... It has a 5 yr warrant, hard floor kits are available, and it is a dry foam process. It is actually the only method guaranteed to NOT void your warranty on your carpet. Also I have 6 kids, a large pitt bull, and if it can de-stain my rugs..... Well just say it has a glowing endorsement.....
  • 3 Answers
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes do not rotate when cleaning carpet. Is in carpet clean mode and will not rotate. I did clear the filter underneath.
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism
Oct 22, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam VAc carpet Model F7425-900
Take out the brush block, make sure that the shaft is ok, it goes up into the turbine, which is what drives the brushes. If the shaft is ok, then the turbine either needs to be cleaned and lubed, or replaced.
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
2,933 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
