Question about Car Audio & Video
Amp hi my name is matt judah and i got a 6200 watt lanzar amp with 3 audio fonics 10's and i am not real sure how to hook them up to make the best sound. I was wondering if you could help me out.
  • judah1990 Feb 29, 2008
    yes i am.
  • vvvvvvvv Mar 28, 2008
    how do you hook up 3 speakers to a 2 chanel amp
  • 4 Answers
Matt, first of all are you familiar with car audio install? if you are ihave an answer if your not i have a different answer..............
Posted on Feb 23, 2008
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
I paid a store to hook up my lanzar vibe 241 amp and 2 lanzar 12" subs(all brand new). It sounds ok but i have a loud buzzing coming out of it constantly and when i use my power window buttons I hear a...
To get rid of the buzzing sound just go to walmart and in the car stereo section buy the $10 rca ground loop isolator, this is the best way to get rid of amp noise
Oct 11, 2009 | Lanzar VIBE241 Car Audio Amplifier
Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
May 03, 2009 | Lanzar MXA242 Car Audio Amplifier
When i hook up power sparks mosfets get hot real hot like a dead short i replaced the mosfets all eight were fryed big time most had burned right side leg off lanzar 1000 watt car amp
It is clear that there are serious internal issues with this amp, and that diagnosis - parts - labor could be upwards of $200.00 while it only retails for $99.00
Saving it is not cost effective.
Good luck
Aduz
Mar 28, 2009 | Lanzar 2CH 600W VIBERANT AMP Car Audio...
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
