Question about InFocus X1 Multimedia Projector
InFocus IN74 Projector Fault
I have the abovementioned Projector. All of a sudden yesterday I turned the Projector on as normal and then about 20 seconds later the picture was gone and a red light has been flashing since.
I have tried turning it off at the power point and back on again and the same thing keeps happening.
Could you please offer some advice as to how to fix the Projector or what may be faulty?
Thanks
Kate
  • smoky1 Mar 15, 2008
    We had a red light flashing and no picture. We unplugged it and then the green light came on blinking, the picture came on for about 20 seconds then stopped and the red light started flashing. We unplugged it and then plugged it back in again (after waiting about 10 seconds). This time smoke poured out of the projector. Any ideas on what happened?
    Thanks!
    Problem Solver:
  • 16 Answers
Hi there.
How many hours had it done? The bulb may have expired and as a safety precaution the projector will not switch on, otherwise the bulb will explode causeing further damage.
Cheers
Posted on Feb 29, 2008
  • 3 Answers
Was it mounted on the ceiling? There is a power supply/ballast board inside that goes bad. I have seen some where the board is actually burned on the other side from where the ballasts are. Chances are the bulb is fine but the ballasts failed. Other symptoms are dim or flickering picture with low hours on the bulb. This is a well know problem with these projectors but infocus wont do anything about it.
Posted on May 09, 2010
Projector shuts off, and the start-button light blinks red in 3-blink sets. Unplugging and plugging back in then hitting start button gets it going again. What is the problem?
Does it switch off after being used for some time?
Actually, from your question it is not clear. But you can open the cover and check for dust, specially at the air filters.
Most used projectors have this problem. If the air filters are blocked with dust, the the projector will overheat and switch off.
Sep 25, 2011 | InFocus IN74 DLP Projector
When I turn the projector on, it goes about 2 minutes, the picture (lamp) flickers and then it shuts down. I can pull the power cord and when I plug it back in, it will start up again but repeates the...
I also had the same problem and finally we heard some glass shattering sound. I opened the projector cover and found signs of burning and one part separated ?diode or what I do not know. I can see a small hole on the board possibly where the wire got broke and the piece became separated and resulted in a shattered noise, I suppose.
Dec 31, 2010 | InFocus Play Big IN76 Multimedia Projector
Thin black vertical lines in infocus projector screenplay 7205
normally, i'd say av solutions in ny, but they don't ship out of country. try www.projectordoctor.com.
Jan 22, 2010 | InFocus ScreenPlay 7205 Multimedia...
The start up screen is on with no signal through
Try a firmware upgrade.
http://www.infocus.com/Support/Products/Projectors/IN76.aspx
Oct 24, 2009 | InFocus Play Big IN76 Multimedia Projector
Turns of suddenly
see what the leds on the top are doing. what colors? are they blinking or still? if they are blinking, how many times? this will let you know what the problem is. shortcut: it's either the lamp is close to 2000 hours, it's overheating (dirty or no air flow), one or more of the fans are bad, or the power supply is not sufficiently supplying power.
Oct 13, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
InFocus X1 Multimedia Projector Logo
478 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
