Question about Kenmore 63942 Dryer
Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
I need to replace the Lint Filter - Trap Door - What ever you want to call it... do you have these... Thanks Donna C
PS. The model described below is not my dryer the one listed above is - which you do not list....
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does the dryer have a lint filter in the door? Or, is it located on the top of the dryer? I need to know this in order to give you the proper advice on how to check the interior. You could have a clog in the air blower tubing. Post back to this thread please.
  • Jeff Rockwell
    Could you please post back with your model number (located somewhere along the door opening) so I can give you a better answer? Are you simply replacing the lint filter? Or, are you replacing the housing that the lint filter goes into? Please provide me with some specifics.
  • Anonymous Mar 28, 2014
    Need to replace the signature 2000 dryer lint filter, model # FFT 8308 80D
I need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Posted on Mar 12, 2008
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
I have a Kenmore 80 series heavy duty dryer that is not giving out much heat.What should I be looking for to solve the problem?
Is it gas or electrric? Either one i would check the dryer vent hoses. Check the lint trap as well. The lint trp is the exit for the hot air to circulate. Sometimes if clogged with lint these dryers could go either way they could over heat and cause a fire or cause the element or thermostat to fail. The electric dryers have a thermostat and a heating element. Those tend to go bad. Back panel should be taken off and unplug unit check.
Apr 03, 2011 | Kenmore Dryers
My Kenmore Heavy Duty 60 Series Soft Heat Large Capacity dryer runs but not drying the clothes. Also runs constantly after the time has run out. Can you give me some assistance?
Dryers need airflow to work properly.
Unplug the unit and pull away from wall. Use flashlight, gloves, etc. as neccessary to inspect ducting for dryer lint. Remove any and all lint. Use a shop vac to clean vents and area. You might also need to use the shop vac to vaccuum out or blow out ducting.
Another typical solution is to replace the two thermostat controllers.
Parts available from Sears parts online for around $20 each.
Unplug Dryer and remove back panel from unit (8-10 screws.) A Simple pair of pliers will do the trick. Use shop vac to remove any and all dryer lint from inside unit. Thermostats look to be central right and easily accessible.
I am not a professional by any means, but I was a mechanical engineer on a nuclear submarine's reactor plant and I did work for 6 months installing and light repair on Maytag appliances.
I have seen several websites with info that supports the problem being the thermostats. My guess is that I would treat this like replacing headlights for your car. Never replace just one, because the older one will not be as bright and will most likely fail in the near future. For the low cost and high effort to go back and replace a second thermostat...you might as well replace both at the same time.
Dec 29, 2010 | Kenmore 63942 Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Dryers
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Manual for a Kenmoore 60 series soft heat large capacity dryer.
Here is the website for Kenmore driers and the manuals to download for free in Adobe format. They are only listed by model number.
http://www.kenmore.com/shc/s/search_10154_12604?vName=Kenmore&cName=Washers+%26+Dryers&keyword=kenmore+drier&sLevel=0
Dec 22, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
1,256 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
