PLEASE HELP!! The power button on the tv will not shut the tv off. You have to use the remote to turn it on and off. Once you power the tv on with the remote the tv turns on but a few seconds after being on the picture menu pops up....after a few seconds goes off and continues to do this non stop. Also, the power indicator light continuosly flashes, the remote will not work to move up or down on the picture menu to try and exit or change it nothing seems to work. It just happened last night and it's getting very frustrating! Please help or give some suggestions!! Thank you for any help!
    Novelist:
    Champion:
  • 275 Answers
In all likelihood, the TV's Main Power ON/OFF switch is faulty. Get it replaced.
Posted on Feb 23, 2008
Have an Element TV and the remote will shut the TV off and on plus do the SAT/CAB Directv I can turn on and off but the channels won't gel so I can watch The TV
Search Results
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code. ... All the steps you'll need to program your Rogers Remote to control all your home theatre devices. .... the Cable turns on and off and volume etc. but will not shut offthe tv. ..... I bought a Element Electronic Smart TV and have set it up.
    Support ' Element Electronics - Elementelectronics.com
    www.elementelectronics.com/support/
    Element ElectronicsA description for this result is not available because of this site's robots.txt - learn more.
    DIRECTV - Support: Your Remote Control
    www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
    DirecTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On until they ... Power Key - Your DIRECTV™ Remote can operate alternate devices.
    [PDF]Get to know your remote control Need more help ... - AT&T
Jan 31, 2016 | RCA Televison & Video
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Remote codes for the 22LV506 for a dish network remote please. none of the provided codes for this tv work. Thanks, Frank
You can power scan any dish network remote for the correct code by pressing and holding down the tv button(clear or gray button at the top of the remote) until the lights all light up, release the tv button. Press the larger red power button (not the red tv button) release button then press the channel up button repeatly givng time for tv to shut off. Once tv shuts off press pound key and red tv button to turn tv back on, Press sat key to go back to satellite mode.
Jun 19, 2010 | Toshiba 22LV506 21.9 in. LCD HDTV/DVD...
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Have a samsung tv. I need the code for a PX-RC1 universal remote for the tv.Can anyone help.Thank-you.
Try the following steps:
1. Turn on your tv. 2. Press and hold the "set" button, then press the "tv" button. 3. Release the buttons. Then, press "set" once more. Point the remote at the tv. 4. Press the power button repeatedly until the tv shuts off. 5. When the tv powers off, press the "tv" button one more time. Your remote should be programed to the tv.
To program other devices into the remote, use the same procedure described above, except press the corresponding key for the device instead of "tv." ex: to program the vcr, press "vcr" instead of "tv."
I hope this helps, and good luck! Sincerely, Der Strom
Apr 12, 2010 | Radio Shack 15-2142 Remote Control
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Programming my remote to control the sound on my TV
3)press pound sign
Jul 24, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
3)press pound sign
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Dish network
Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
3)press pound sign
To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
Dec 11, 2007 | DISH Network IR Remote Control
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
