Denon DRA 455
Hi There
I have a DRA 455 with no power to the main CCT.The Red Led is on , The fuses are fine : I cannot find any obvious diodes damaged.
Thx for reading this
Skyworth
  • 2 more comments
  • Maetti Mar 18, 2008
    hi ive got the same problem - can you help me?
  • djdavec Jul 06, 2008
    the problem i have with the dennon dra 455 theres 8 speakers running of it it has gone of AGAIN the red lights on but it wnt go on even using the remote control.......is there any one that cud fix this problem as its the second dennon in 2 months....pls help
  • john morgans Jan 22, 2009
    i have the same problem and yes i have a multi meter thanks
  • Graeme Ross
    Graeme Ross May 11, 2010
    do you have a multi meter to make a few measurements?
  • 1,512 Answers
Hey Skyworth
If you had a meter, I could have talked you through making a few diagnostic tests. Get back to me here with a comment if you want to have a go:)
regards
Graeme
Posted on Mar 02, 2008
Denon DAR-395 sparks
You most likely have shorted output transistors. This will cause the fuse to blow, and usually burns up a couple resistors as well.
Apr 22, 2013 | Denon DRA-395 Receiver
The power supply has burnt out on my denon dra-455 reciver.
It really depends what and how much burn't up? The only way to find out it to take the top cover off and look inside. A lot of parts in the power supply section can only be replaced by excat parts due to safety reasons. And are you certain it's the power supply that's gone up, and not the POWER AMP section? It could be just one part that started smoking. If any semi-conductor has burnt up, you might not be able to read the code number, in which case you will need the service manual.
SO GET LOOKING INSIDE!
Jul 01, 2010 | Denon DRA-455 Receiver
Hi all i have a Denon DRA 455 with Eltax Linear 6.5 wich is 8ohms i have a sub but no sub output, apart from sharing power between them, how can i hook these up please? thanks
You did not state if your sub is a powered sub or not, but if you use the "B" channel for your sub, it should work. This is possible if the denon will work with "A" channel and 'B" channel on together. The back of the Denon should have two sets of speaker outputs. Connect the "B" channel speaker outputs to the sub. The "A" channel will still drive your 6.5's.
Aug 05, 2009 | Audio Players & Recorders
Denon DRA-354r
I have traced the fault to the rf amplfier transistor in the tuner "can" It is a 4 pin item with 6JK85 on the encapsulation but have been unable to source a replacement. Can anyone help?
May 27, 2009 | Denon DRA-455 Receiver
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Stuck in standy
if the amp comes on in standby that means it needs repair
Jan 26, 2009 | Denon DRA-455 Receiver
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
Right channel not working
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
179 people viewed this question
 Grubhead
Grubhead
