Televison & Video Logo
Y.K. Jayasundera Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Philips TV Model No. 21 pt 2622 - 69 r Power side is not work
Please show me its PCB diagram
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Feb 23, 2008
Anonymous
Expert
Level 2:
Answers
62
Questions
Helped
26357
Points
101
Hii...
What is Philips TV model " no.21 pt 2622-69 " ?
Thank's
[Vrya]
2answers
Tv philips 21pt2443 schematic diagram
Schematic diagrams are in PDF, and cannot include by this window. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
I have Philips 21 RF Vardaan TV. No sound is coming on channels but picture is perfect. AVI blinks but still no sound is there. It now also shows AV2 and Front which earlier were not shown. Please help to...
Looks like sound circuit problem. Check ear-phone jack if one is fitted in your model. Check speaker. Check the sound I C power supply. fI you have circuit you can follow.
Otherwise search the I C no in Google and trace the faulty area. To trace the sound IC just follow the speaker wire connected to the PCB. Mostly the IC will be close to this connector or joint.
1helpful
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
2helpful
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
2helpful
Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
6helpful
2answers
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Mitsubishi CK3560R
Good Day;
Try these first. This TV is an oldie 1988?
POWER SUPPLY STARTS BUT WONT RUN. CHECK FOR SHORTED D909 OFF T905 PIN 17 AND/OR SHORTED IC401. (PCB-MAIN) D909 PT.# 264P521020 IC401 PT.# 272P174010 *** ( TO PREVENT REPEAT FAILURE , REMOVE T905 FROM PCB AND RE-SOLDER LEGS OF TRANSFORMER AND THEN REINSTALL) 2. POWER SUPPLY WONT RUN. CHECK FOR OPEN FOIL AT PIN 2 OF T905. (PCB-MAIN) 3. POWER SUPPLY WONT RUN. CHECK FOR OPEN R903 (220KOHM) AT PIN 3 OF IC901. (PCB-MAIN). ALSO CHECK THE VERTICAL OUT IC, LOOK IN POWER SUPPLY CIRCUIT FOR LEAKY CAPS. YOU CAN TELL BY BLACKNESS ON THE BOARDS ON THE NEGATIVE SIDE OF THE CAPS.
Good Luck, big IRISH.
Need cct diagram or can I buy a new power supply pcb for a Philips 20PF4121
May have psu for this model please let me know no`s.on psu board.before it went completely did you have sound but no picture?
may be able to suggest solution if this is the case.SUPER8.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
