Question about Miele CVA4070 Coffee Maker
Miele CVA4085 coffee machine
What is Fault 10...?
i have miss placed my manual and the machine will not work!
i have checked everything even the contacts on the drip tray!
HELP!
thanks
Ms Jones
  • 2,039 Answers
No water in tank or water valve close thanks for using fixya pierre
Posted on Feb 24, 2008
Trying to descale Miele coffee system-- keep getting alternating faults --10 or 17.
These codes relate to a water supply problem. If this is a plumbed system then check the water is turned on and hoses are not kinked. There is also a valve at the bottom of the water container outlet that may be clogged. Other than this its an internal fault with flow meter or coffee/hot water pump. Regards
Apr 16, 2017 | Miele Coffee Makers & Espresso Machines
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
Miele CVA5065 coffee machine has fault 77
I am not familiar with a CVA 5065 - but most of the other Miele coffee systems fault 77 is the ceramic valve initialization or the switch (S51) associated with it.
Apr 20, 2014 | Miele Coffee Makers & Espresso Machines
Coffee machine steam wand pressure issue
Good question. I have been surprised before today after checking the manual for various gadgets. There are thousands of manuals online which can be searched for if it is missing. We have a bench top water filter fitted. When you have one of those, the difference is so noticeable that you will only want drinking water from there
Feb 28, 2014 | Coffee Makers & Espresso Machines
Miele coffee system CVA 2660 is showing fault #10 while I descale and won't let me finish the program. I restart the program by turning off the system but I get the same fault message after about 20...
F10 is a water intake fault. The are several possibilities: the pump may be defective, a piece of lime scale may have blocked a pipe, the water tank might be faulty. Most likely is the pump.
Jun 17, 2010 | Miele CVA615 Espresso Machine
Fault 10..
If it's new then contact supplying dealer and get it fixed under warranty.
Jan 15, 2010 | Miele CVA4070 Coffee Maker
Fault 10 appeared
Fault 10 indicates "No Water is Dispensed."
Solutions =>
– The water tank is not inserted properly. Take it out and reinsert correctly.
– The water tank was not filled correctly during the descaling process. Fill the water tank up to the correct mark.
– After fixing the fault, the machine turns off then on again. Start the desired preparation again.
– If the message still appears contact Technical Service
See page 52 for Fault Codes and Solutions in the owners manual.
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Sep 07, 2008 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
654 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
