Question about Maxtor Hard Drive
Missing installation cd
I am putting the hard drive in a different computer
    Genius:
  • 1,019 Answers
you,ll need to format the drive first.
connect the IDE Cable ( 40-80 Strand Ribbon )
And 4 Pin Power plug ( Molex )
you don,t need an installation disk to do this.
enter the bios setup, and ensure your drive is seen by the computer.
install windows et,c.
away you go.
Mike @ Compurepair.
Posted on Feb 23, 2008
How do fix Hp compaq d530 ''NTDLR missing''
First make sure there are no disks in any of the drives cd floppy and usb Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable
Failing to enable USB keyboard support in the BIOS.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette
Test all power and data leads that attach to your hard drive including IDE,SATA
if ita flat 40 pin ribbon type it will be the first to fail.
The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer.
A missing NTLDR means that your computer cannot boot to the operating system.
This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR.
Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
Restart your computer.
When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup."
Most computers are configured to boot to another device other than a hard drive.
Since the Windows XP/2000 installation disk is bootable, you should see the prompt.
However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup.
Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive.
Then reboot your computer.
After you have pressed any key, the Windows XP/2000 setup screen will appear.
After loading, press the "R" key to repair the Windows installation.
The screen will appear black.
The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter."
If you have more than one hard drive or more than one partition, the procedure may be different.
You must know which hard drive or partition your Windows operating system is installed in.
You are subsequently prompted for a password.
If you haven't set up one up, you can just leave the query blank and press "Enter."
The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one).
Eject the CD from the drive and type "Exit" (without quotes) to restart your computer.
The NTLDR file will be copied from the installation disc to your hard drive.
or
If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further.
This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer.
Restart the computer and press any key on your keyboard when the message prompting you to do so appears.
Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system.
Type in your Administrator password (if needed) and press "Enter."
Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter."
Restart your computer and let it boot up normally.
Since the NTLDR is freshly restored, the computer boots up properly.
Hope this helps.
Dec 03, 2012 | Computers & Internet
PC will not boot, BOOTMGR is missing. What do I need to do?
I assume it's Windows 7.
Check that the BIOS is set to boot from CD/DVD as the first boot device and then put the Windows installation disk into the drive. If done correctly then the PC should boot from the CD/DVD and then just follow the on screen instructions (follow the instructions and select the repair option).
Jun 08, 2012 | Computers & Internet
Can I put a bigger hard drive in my Dell Latitude c600 laptop?
You need a laptop IDE hard disk.
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 07, 2011 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
NTDLR missing error
option 1: you have to reinstall windows
option 2: take out your harddrive. put it in to a compter with same OS and copy that compyter ntdlr file to c:\
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 29, 2010 | Acer Aspire 4520-5582 Notebook
NTLDR is missing in my computer
Missing NTLDR can be caused by any one of these problems :-
Corrupt NTLDR and/or NTDETECT.COM file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
Loose or Faulty IDE/EIDE hard disk drive cable.
With Windows XP follow these instructions
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this doesn't work, then the last resort is to install Windows again, plus the computers device drivers and your programs.
Feb 11, 2010 | Computers & Internet
When installing xp on new hard drive in a gateway GT5056 it says NTLDR is missing What does this mean
If you are attempting to install Windows XP and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
When the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Aug 16, 2009 | Computers & Internet
I purchased a 'broken' c400 off ebay, rather foolishly thinking it's an easy fix.... Basically I need to find a way to install an operating system on the computer - it has no cd drive, no floppy and...
Honestly with so many things that are missing and so many things acting weird on you, your best bet is to get a known working hard drive in there and also a know working cd drive in your laptop. This way you know for sure those two components are working properly and you can try a fresh install of XP from a good working cd drive and onto a know good working hard drive.
If you now have problems then from this point it can legitimately be narrowed down to a memory, CPU or motherboard issue.
This really is the best way to try troubleshooting this problem with so many components missing.
Always a good idea to stick to doing things on the same computer instead of doing lots of swapping between hard drives.
If you need further help, feel free to let me know.
Jul 14, 2009 | Dell Latitude C400 Notebook
I missed my hard drive disk and now i formated my laptop i need hard drive disk because i dont have audio,wireless,etc installed .MY LAPTOP SET IS-Compaq Notebook PC .Presario C500 s/n:CND7090BHC...
Compaq has a website with downloadable drivers for all their computers. Download the drivers, burn to CD and install. Trick is, one model could have different components inside, so they list several different drivers, and not all drivers work with all computers. So unless you know what components are inside your computer, you need all the drivers and just try them until you get the right one.
Jun 10, 2009 | Compaq 10.2 GB ATA-100 Hard Drive
Have ide drive have put a new 60gig but cant load new os it finds the cd drive but wont boot from disk have changed bios but still it say ntdlr missing it drivin me nutts.
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows.
  9. Loose or Faulty IDE/EIDE hard disk drive cable
  10. .
To Fix
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot
Jun 01, 2009 | Fujitsu Siemens LifeBook S-6000 Notebook
Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Feb 05, 2008 | Microsoft Windows XP Professional With...
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
