Question about Nokia 2310 Cellular Phone
I haven't activated mine yet , going to in 2 days , but trying ti understand or synchronise things at present , difficult . book inadequate
Please should I download something or go to a particular web site .
  • jyots Mar 01, 2008
    hi i can't unlock my security code for nokia 2310
    please e-mail me to at
    i'll give you my imei
    please help me
    Brigadier General:
  • 7,752 Answers
Skrapi - call your mobile provider
jyots - you can email me the IMEI#
Posted on Mar 27, 2008
2003 Focus zx5 with a 5 speed manual. Yesterday after driving about 50 miles it became more and more difficult to push into all gears but would go if forced. Clutch worked and could drive it but could hear...
The transmission has synchronisers to help line up the gears when you shift from one gear to another. If this transmission has been treated rough or rawhided and speed shifted, these synchroniser clips become bent and turn up and won't allow the synchroniser to slid over them into place and hold the transmission in gear. Eventually you will have to replace them. You will notice if you take it easy when shifting, it will get easier. Don't get in a hurry and jam the shifter or it will just get worse and they will have to be replaced. I hope you better understand how your shifter work. I hope you can buy some time before you have to put a fair amount of money it to it.
Good Luck.
Feb 10, 2015 | 2003 Ford Focus
Outputs of TI analog 500-5016 do not change when inputs to Ti 520 controller are changed. Mother board consists of power supply , TI 520c controller, TI 500-5016 analog output, TI 500-5009 analog input,...
hi, The VERY first thing we MUST check, is the PSU, check this exhaustively, even if possible replace with a know good, as if this isn't 100% A OK, NOTHING else can be..then well ADC 101 says that if there is NO output from the ADC, then this can only be due to 2 reasons, one, it is Inhibited, two, there is NO DATA to be converted/coming out? We need to find out why?
You need to use a 'scope and view the input and output signals along with the lines that control the IC, data flow, Inhibit etc, and see if all the lines are in the correct logic states, work back along either the control lines or signal, and work out why either it is inhibited or lacking signal.
Also check that you micro, isn't inhibiting it either?
Start at the beginning, where the analog signal is presented, and follow a line(s) along through the circuit with the 'scope, checking where they enter the conversion IC, then look at the Output(s) and see whats what, now if all control lines are set OK, and there is NO output then that IC must be faulty... anyway follow the signal along and see why it's not working..
unfortunately there could be many, many conditions that can cause this type of thing, one simply? must work through each block of the circuit, isolating sections if possible and viewing the activity on a 'scope to see where it all goes wrong. checking the voltage and signal levels are correct.
Mar 20, 2011 | Texas Instruments Computers & Internet
Windshield washer not working
Two problems typically cause this condition. 1). Clogged or Leaking flexible hoses connecting the system to the Wiper Arms and/or clogged Jets on the Arms. 2). Inadequate Solvent for the Pump to Pump it or a defective Pump.
Have you checked to see if you have Electrical Power to the pump? This requires 2 people one to activate the Switch and one to connect a TEST Light to the Various Terminals on the connector Typically 2. The Test Light should be Grounded to the Engine Block or a Clean known Ground Point on the Sheet Metal such as a Bolt Head that is not corroded. If Voltage is present on one wire when the Switch is activated then the other wire is Ground. The integrity of the Ground connection can also be Tested with the Test Light by connecting it to the Positive Battery Terminal and Probing the Lead that is supposed to be Ground. If both +12V and Ground are Good and the Test Light Indicates that +12 is coming from the Switch then you probably have a defective Pump. If you have no voltage present on either wire when the Switch is Activated it may be a Blown Fuse or Defective Switch.
Dec 07, 2009 | 2005 Buick LeSabre
How to set up four decimal point for TI-83 plus? Mine right now is 2 decimal point.
Do you mean four places behind the decimal point? Page 21 describes setting for fixed decimal point 0 thru 9 places to the right.$book-eng.pdf
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
10 2/7% change to fraction- I need to know calculator steps using the "abc " key -what are the steps to complete this function? I dont understand my book instructions - thanks
10[ab/c]2[ab/c]7 [=] enters and displays the improper fraction 10u2u7
[2nd][%] [2nd][d/c] gives the result as a fraction Result is 18/175
You can also try
Hope it helps
Aug 23, 2009 | Texas Instruments TI-30XA Calculator
I have a Magnavox ZV427MG9 DVD recorder. I follow instructions on how to finalize recorded DVD but it doesn't work. I set up to finalize at the beginning and it won't work. When I try to finalize at the...
what you do after you label the recording you play the dvd selecting the image and then play then stop it then select setup.
The instruction book doesn't follow through properly and I lost a dvd that way before I realized what it was after trying on a test DVD different things to get back to the setup screen that was supposed to have the finalize on it.
It's also a 1/4 inch to wide to fit on my shelf so it sits on top and blocks the remote sensor on the tv and makes tv control a bit difficult. The copies if you get them right at the fastest speed are very good though.
Many VCR's are protected from copy. Some start with that right away disabling the copy process others wait till thee film is half recorded. I understand some makes don't respect the copy proofing on tapes. I am not so experienced to say for sure that is so.
Feb 21, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Iwould like to learn how to use the ti-89 for pre-algebra.
there is a book ti-89 for dummies and I have heard good things about it
Jan 21, 2009 | Texas Instruments TI-89 Calculator
Nokia 2310 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
