Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Digital Convergence Mode
I have a phillips rear projection tv and I know the code ( 0 -6 - 2 - 5 - 9 - 7) to access the menus, but have a hard time entering through the remote.
  • 137 Answers
Jou must hold in the menu button wille putting set on and press the code wile hulding in the menu button on tv.
Posted on Jun 29, 2008
How do i reset my mitsubishi television model#ws-55511
First a reset may not help unless I know what your problem is.
If model listed (WS-55511) IS CORRECT: set has 3 hidden menus:
Option Menu (hard reset of all settings to factory)
Technical Menu (Adjustments for various things)
Convergence Menu for adjusting convergence.
THESE ARE NOT ACCESSED FROM CUSTOMER MENU. Each requires Mitsubishi remote and a 4 digit code .......
So, What is your issue with the set?
I have the codes but it depends on model number and what problem with set is, reset is in Option menu but will not cure all problems.
SD TECH
Nov 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Mitsubishi WS65809 HD input (DTV) not working correctly. I replace the convergence chips in this TV and was making adjustments in the service menu. Everything was lined up and working great. The HD input...
All these sets do have a hard reset---not the reset button on the front of the set---it will return the set to the factory original condition it was when new in the box--it will not affect the convergence as that is stored in a separate unit--the DCU (digital convergence unit).
It is accessed with an original MITSUBISHI remote.
You can try it if you want:
ACCESS CODE FOR WS65809 IS:
menu-0,1,7,0 enter
There are 3 hidden menus in the set--this is the Option menu
You will see either reset or option etc and highlight it with the remote and hit enter. Set will shut off and should come back on channel three in the air band--any labels you placed on inputs will be gone and set will be in air band--you will if on cable have to change it to cable band and auto program etc.
Let me know what happens and if you have questions I am here to help.
SD TECH
Feb 02, 2010 | Mitsubishi WS-55809 55" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Convergence
hello theres a couple of codes you can try .1-2-7-0/2-4-5-7/0-3-5-3 /0-3-5-7 do not use the reset it may cause damage ti the tv good luck
shaun
Apr 10, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
