Question about HP Compaq Presario V2000 Notebook
Touch pad cover
HELLO I HAVE A PERSARIO V 2000 ( V2030US), AND NEED A TOUCH PAD COVER ONLY. EVERY WHERE I LOOK I CAN ONLY FIND THE WHOLE TOP COVER. CAN I BUY THE TOUCH PAD COVER ONLY ?
THANK YOU
CHRIS HOLOMON
e-mail: jchguns@aol.com
or : chris_ann@bellsouth.net
    Master:
  • 474 Answers
Most likely not, unless its dtraight from the manufacturer or someone sells you there parts, i would just get the whole cover, it will make it easier anyway, than trying to spend time and money looking for just the pad.
Posted on Feb 23, 2008
How do i get the panel off to get to the touch pad maytag mmv4203db00
Remove the cover that makes up the microwave shell. There should be screws in the back that hold it on. Once free of the base just pull the cover off to the side. The Control Panel should now be exposed. I pulled up the schematic at "Sears Parts Direct" and don't see any screws holding the pad in place so it appears to be a snap fit connector at the top of the pad that it mates to. You should be able to press the plastic snap fit to dislodge it. Otherwise you'll need a small flat blade screwdriver at the top to unlock the latch mechanism. Lightly press down and it should just pop off.
Two places to search for the schematics is searspartsdirect.com or appliancepartspro.com.
Hope this helps.
Jun 08, 2014 | Maytag Microwave Ovens
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
Aug 13, 2013 | LG LMV1630 Convection/Microwave Oven
Hi, I am using HTC touch P3450 model.Suddenly touch screen is not responding.So I gave a hard reset for factory restore settings.After loading the OS its asking to TAP the screen,but my touch is not...
Your touch pad need to be replaced. I had the same problem and order a complete face lift which includes the touch pad from ebay. It was included aslo the special tools needed to remove the screws. There many videos showing how to desasemble the phone in youtube, just search with your model and you will find videos showing all the dtails how.
Please not that the problem is with touch pad which is the one you touch directly on it, is only vinil cover and is working as a keyboard. Under touch pad is located the lcd display of the phone which other part .
Feb 28, 2011 | HTC Touch P3450 Smartphone
Cant find my manual, but the error code is F-21
Remove your service panel and you will find your tech sheet tucked neatly away inside a plastic keeper in that service panel.
The F-21 on your model is:
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Remove the top cover:themobilian_1466.jpg
Check your connection for corrosion or soap dripping into the top of the machine. It is advised not to set anything on top the washer that might drip into the controls.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
Jan 18, 2010 | Samsung Microwave Ovens
The left key on my dell touchpad is not working
that part of the touch pad is not working anymore, its faulty and you need to replace the whole touch pad.
I don't know why this is mostly common with Dell. My friend has a Dell inspirion 1501 and the touch pad has exactly the same problem as yours.
I would advice you get a USB mouse to keep you going pending the time you get the touch pad fixed.
I wish you the best of luck.
Jan 06, 2010 | Dell F3534 Touchpad
How do i change the heating fuse for a ge spacemaker microwave
unplug first, take three screws out of top vent cover and there may even be some on the top cabinet holding vent cover on front, then you might see fuse holder just behind vent cover, if not remove screw(s) holding touch pad on, then slide touch panel up and out. it will rest on hinge, then you should see fuse holder inside behind touch panel. BE SURE TO UNPLUG FIRST AS ELECTRICITY CAL KILL YOU.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Laptop Touch Pad wire
There's no possible to repair that touch pad wire, its coated, very thin and it's delicately to put it back again.
As you say that you spend $77.00 then do it. If for your own good. And use that touch pad again.
I'm sure you're happy about that.
Hope this tip might help you. Good luck!
Aug 08, 2009 | Computers & Internet
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
