Question about Philips 25PS40S 25" TV
Toshiba 32 SDTV
The tv just showes a black screen with a line through it. There is still sound but it just showes a bright line through the middle of the screen what wrong??
    Genius:
  • 1,694 Answers
Resolder vertical output IC as a first step in case that is all it
needs...............................................T.
Posted on Feb 23, 2008
  • 2,130 Answers
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Toshiba 32 AV502R LCD TV has a horizontal red line in the middle of the screen, then after a while you can see two colors
Sounds like a defective LCD panel, but I would recommend a diagnoses to get a second opinion.
Oct 27, 2012 | Toshiba 32AV502R LCD TV
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
Apr 05, 2012 | Toshiba 32SL410U 32 LCD TV
Have a rca, sdtv, 32", screen stopped working.
Nope, you have a bad part inside.
It's fix or replace time.
Jan 06, 2010 | Televison & Video
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
TV Fault to toshiba 1998 model tv
this normaly means the tube inside the tv has blown there is no fix for this you could try unpluging it and pluging it back in well its on and see if theres nobes on the back to turn try turning them and see what happends otherwize it means your tube is blown
Mar 27, 2009 | Toshiba 32A33 32" TV
Black screen with colorful line going horizontally through the middle of the screen
Problem in the vertical circuitry.
If you have the know-how, check for "cold-solder" joints around vertical i.c.
Also, bad electrolytic caps.
Voltages ok?
Resistor values ok?
Replace I.C.
Don't tell me the yoke wires were off or gnawed thru by a roach!
Aug 07, 2008 | Toshiba 32A33 32" TV
Duraband 19'' TV shows one horizontal bright line ONLY
Yes there is, a solution. There is a vertical sweep issue with your TV set. It could be a vertical output IC and or the sweep power supply feeding the IC. This repair will involve trouble shooting the vertical circuit, and replacing parts. If you have no solid state repair experience, my best advice would be to take the set into a repair shop and get an estimate on this TV. The repair, in most cases, should not exceed 125 bucks, and thats a high end cost. Good Luck
Jun 20, 2007 | Durabrand DWT1905 TV
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Philips 25PS40S 25" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
