Here is a disassable method in photos (of mine) https://docs.google.com/present/view?id=dhpc55mv_472fc5s52gp
There is no such thing. There is only a users manual.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00594/C875_GLB_en.pdf
Please explain your issue.
Hey welcome to fixya. i hope u'll be fine.
if u like the solution Kindly do Rate me
For Video Click Here
Keep using fixya
Thanks
SOURCE: kodak camera insert
the dock insert for Kodak cameras are given for free and are not for sale anywhere. call Kodak at 1.800.235.6325 for free dock insert
SOURCE: kodak easyshare c875 flash not
I have the C875 - and had the same problem. It was out of warranty so I took it apart and found that the flex print wiring between the flash electronics and the flash unit was bad. It has 4 wire runs and at least one of them was broken. I cut the flex out and soldered in 4 fine insulated wires in its place. The flash works fine now. The hardest chore is taking the camera apart.
Warning: Wear rubber gloves since high voltage is stored in the flash capacitor even with the batteries out. I got zapped several times.
1) Remove all screws on the left side, right side, and bottom (including 2 inside the SD card door). Remove any SD card.
2) Remove the lanyard attachment fitting and then front and back covers.
3) Remove screws holding the metal center band in place. I recall there's a hidden one that's a long reach inside to remove.
4) Bend the band down to clear the tripod mounting hole and slide it off toward the front. Watch out for the fine speaker wires which will tether the band to the camera. I broke one and had to resolder it during reassembly.
5) You will see the orange colored flex leading to the flash. Snap out the flash.
6) At this point you could check the continuity of each wire to confirm the problem.
7) Cut/strip 4 wires to match the lengths of the runs. Use very fine insulated wires - 30AWG or so. Thicker wire might not fit.
8) Note the wire routing. Cut out and desolder the old flex print.
9) Solder in the new wires
10) Snap the flash back in place and dress the wires like the old flex print.
11 Reassemble. You can test it once you put the metal band back in place.
Ther C875 is a great pocket camera. One very much worth fixing.
SOURCE: I can't seem to format
The problem is that your camera is only compatible with SD cards, not
SDHC cards. You bought a larger card for your older camera, not
noticing that it was SDHC (or not knowing that it mattered). The new
card doesn't work, not because it or the camera is broken, but because
it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC
cards but some have errors; they disable half of the chip and sell it
as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because
they're cheaper, but 4Gb SD cards do exist. They are so rare that I've
even seen a guru on this site claim they don't. I did own one once, but
it was very expensive and turned out to be so unreliable that I had to
return it. I don't recommend
looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it
doesn't say "SDHC" on it.
SOURCE: I cannot format
The C875 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
