Question about Dell OptiPlex SX270 PC Desktop
Dell sx270 optiplex
System went down on Sunday. Power supply was not the problem. Holding the power button in for 10 secs or replacing the flea battery did not help. I believe it is the motherboard. How do I remove/replace the motherboard? Are there a set of instructions somewhere?
Thanks;
Tom
mullantl@yahoo.com
  • 1 more comment
  • mullantl Feb 23, 2008
    Thanks to all;
    I have taken all of your suggestions and comments and considered them carefully. Thanks so much for all your help.
    I was able to find the dell *.pdf file as noted via hyerlink w/ my tag # and removed the motherboard for a closer look. Pretty easy, I was a bit nerves about playing with the processor/heatsheild, but once I got a closer look I figured out that it just pops out revealing the 4 green screw on the board. I was able to determine the CN# as H1229.
    To answer the issue of why I think it is the board. I spoke with Dell support several times and went through their long methodology of testing the AC Power supply as well as purchasing an inexpensive new one of of ebay. The 5 capacitors marked 'X' are slightly domed on top. The ones marked 'K' and 'T' are flat. Nothing leaks or is swollen. For the most part the systems is the way I purchased it 5 years ago, but I did upgrade the RAM. There has been no other changes. Even with a new AC power supply, used in different outlets (of course), the systems will not post, which is to say that there is no 'amber' or 'green' light activity on the power button at all.
    I will air off the board and try to test it again as a last ditch effort before I consider a new board. Much of what I see is a direct replacement for H1229, but it is earmarked foe a GX270 system.
    I would like to consider a possible fix (replacing the capacitors) if it is not to expensive, in the Northern Va area. The future of this systems is to be used for a cocktail gaming table / spare emergency computer. I think this would be just fine.
    Thanks again for your suggestions;
    Tom
  • Anonymous Jun 11, 2008
    Where to get new capacitors
  • Troy Scott
    Troy Scott May 11, 2010
    How do you know it is dead? What exactly did it do?
    Master:
  • 474 Answers
Its easy on most dells, open the case, disconnect all the cables and remove anything in the way, then just unscrew the boards fastening screws that hold it down. Sometimes its a single screw that holds the board in place, once removed, the board slides out. First try reseating everything, Pull out the memory and put it back in, same for the video card and any other devices, unplug it also and pull out the bios battery for 30 seconds so everything resets.
If the Capacitors on the mother board are swollen or have discharge, then the board is what went bad, The capacitors are the round black cyclinders that stick up from the board, there supposed to have flat tops, like tiiny little soda cans, but when they get heat damage or go bad, the get domes and split at the top and eventually rupture.
Here is the link to the dell site for the repair manual.
http://www.support.dell.com/support/edocs/systems/opsx270/en/sm/index.htm
You can also go to ( www.support.dell.com )
In the middle it has a link to MANUALS, then it has a way for you to look it up by make and model of your PC.
Posted on Feb 23, 2008
  • 37 Answers
    Scholar:
  • 117 Answers
Always start with the simplest solutions. Make sure the wall outlet isn't blown. Check to make sure you power bar isn't shut off.
If those aren't the problems, please give a more detailed description of what you were doing last, what you were downloading (inf anything). Sites you visited...any hardware changes...bios updates..cmos changes....
DELL OPTIPLEX GX 620 PC WONT SATRT ONLY ORANGE LIGHT KEEPS BLINKING
DELL OPTIPLEX GX 620 PC WILL NOT START.
ONLY ORANGE LIGHT.
Aug 31, 2010 | Dell OptiPlex GX620 PC Desktop
My dell sx270 optiplex doesnt powerup somtimes after i unplug power supply
Chances are it's going to be slightly oxidized contacts on a supply part, but it's not broken, just intermittent. Some power supplies use relays to supply the voltage, and their contacts can get oxidized. The fix for this is to take it off it's mounting, open it up, and use paper or a very fine emery cloth to clean the contacts. You can also change the relay, if that doesn't work out. It's not something that will hurt your computer, just a nuisance.
Apr 08, 2010 | Dell OptiPlex SX270 PC Desktop
Power switch dell optiplex sx 270
You problem is most likely caused by faulty capacitors on the motherboard. Most PCs of your age suffered from this. It was a manufacturing defect. Call Dell to see if they will replace it for free. This is a picture of two blown caps so you can id them on your MBmoz-screenshot.png
Aug 17, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell optiplex sx270 version PC.I had shut it down ,as we had a holiday the next day.I later tried to switch it on after my holiday .But it won't switch on .However the power adapter indicator...
it seems like the power button is at fault i doubt it will effect your data unless you pass it to a bad repair man who may erase everything your hard drive is a seperate entity and can be removed for backup
Aug 06, 2009 | Dell OptiPlex SX270 PC Desktop
DELL SX270 WILL NOT COME ON HAVE LITE INSIDE PC
the power supply is probably bad. It's really hard to tell without a little more information. When my power supply went bad on my computer. the hdd light would come on but nothing else and the computer would not even try to start.the power supply puts out several different voltages with both positive and negative outputs.
Aug 01, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell sx270 desktop when I plug it in only the fan works
First of all, keep the front button pressed until the system shuts off. It might be one of several causes:
1) Memory module damaged (or dirty)
2) The processor is damaged, or
3) The motherboard parted off.
Remove the memory modules and test them one by one. Or if you can test them in another PC (assuming both PCs use the same kind of modules).
May 01, 2009 | Dell OptiPlex SX270 PC Desktop
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell OptiPlex SX270 PC Desktop Logo
1,472 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
