Question about Panasonic SC-AK200 CD Shelf System
Turns itself on
Two days ago my stereo started turning itself on. When I turn it off, it will click off for about 20 seconds and then come on again. It still functions like normal when I want to play CDs or listen to the radio, but it will not stay "off" unless I unplug it. It continually will turn itself on, over and over again. Any advice on how to fix this? Thanks!
Hey there, you actually need to press the Stop /-DEMO Button when the device is doing the demo mode...it will take about 8 seconds and it will display "DEMO OFF" and turn off. This procedure needs to be run everytime there is a power failure OR you unplug it from the wall.
Pressing the Stop /-DEMO while it is on will cause it to start the demo while it is running!
Regards, Joel
Posted on Jan 26, 2009
  • 82 Answers
Is the stereo turning itself on or is it going into demo mode? Try this. With the stereo on press and hold the 'Demo' button on the unit. Keep holding till 'demo off' is displayed.
Posted on Mar 29, 2008
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
Stereo turns off while driving and turns back on again
Sounds like a bad connection. It may get knocked loose and cut out, and then make a good connection and restart. Check the wires you can and see if any are loose or have any bare wire showing. If you see a bare spot, that is where all of your electricity is going instead of its intended spot.
Aug 10, 2013 | 2007 Honda CR-V EX
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
Tv switches off
set goes on 20 seconds it goes off
Feb 24, 2008 | RCA TruFlat 27F520T 27" TV
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Panasonic SC-AK200 CD Shelf System Logo
1,607 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
