Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
No signal TRYING to connect my laptop to the vga but no signal
  • 1 more comment
  • primo623 Feb 26, 2008
    it was the fn key = lcd/crt button
    thanx fixya
  • kimann88 Jan 09, 2009
    My laptop and tv are hooked up correctly but my tv is saying "no signal", my laptop brand is Dell Inspiron 6400
  • yvette_2 Jan 21, 2009
    I have a Gateway w/Windows Vista trying to connect the VGA cable to a Digital Lifetsyles LCD TV and I am getting "No Signal"
    Brigadier General:
  • 6,966 Answers
Assuming that you have hooked it correctly using the correct VGA cable,there is power to the LCD TV and the laptop is running and can be seen on its own LCD display, then there could be two possible reasons:
1. you need to press Fn + F? key (once or a couple of times. Fn would be whatever is needed for your laptop to activate its external video output). To be able to determine what the F? key is, you need to post back your laptop brand and model; or
2. Perhaps what might be causing no display in the TV is that the video signal it is receiving is beyond its capability. To correct this, pls:
2.1. lower screen resolution of your laptop's properties.
2.2. it may also be of help if you likewise lower the screen refresh rate.
Both of the above may be adjusted through the appropriate settings in your Display Properties.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 23, 2008
  • Louie  Role
    Louie Role Feb 26, 2008
    Glad to be of assistance and appreciate the rating too.
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
Contect my laptop
When you have set the TV to VGA input power up your laptop. It should detect it.
Mar 09, 2015 | VIA Computers & Internet
I'm trying to connect laptop to Panasonic Viera TC-P46S30 using VGA-HDMI converter. I'm getting 'No signal. ...' box displayed on TV. How can I fix it.
on your computer, go into your vga graphics driver and hit properties, set it for dual and hit apply. close the box. then go to the graphics,options, look for dual. make sure the wire is tightly in your tv and computer. switch your tv to vga. it should be lit. then you should see your desktop on your tv screen.
Dec 11, 2011 | Televison & Video
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
When we turned on the tv it says no signal vga input? It is a polaroid Flat Screen hdtv.
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
A/V Media Tech Guy
Oct 23, 2009 | Polaroid FLM-2632 Television
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
VGA cable to RCA pins assignment
Are you trying to go to a connection like this:
If you are trying to go to composite video (yellow only), you'll need to convert the signal using a PC to TV Converter
Jun 07, 2008 | Vga (CAT5-9000I) (EXTCAT59000I)
You are trying to run a VGA signal to your television? Usually you need a scan converter to do that so the signals will match. Does your laptop have S-Video out? That would be the ideal method.
Jan 08, 2008 | Compaq Presario M2000 Notebook
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
107 people viewed this question
Top Digital Lifestyle Televison & Video Experts
Mohamed Ismail
Mohamed Ismail
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
