Question about HP Pavillion a818n Desktop PC (Refurb) Pentium 515(2.93Ghz) 512MB 160GB (PS453AAR)
Yahoo cannot connect anymore. connection manager has encountered a problem. how can I fix that
  • pureheart Feb 23, 2008
    I have cable modem and it had been working fine. I did go into and erase the cookies and history and that is when I started having problems. All I want to do is go into connection manager and restore what I erased but do not know how to do that. I can connect to email by go ing thru AOL and then into yahoo. I have been working on this for a week and no progress. I know if I go to config sys I could probable solve it but I don't know the lingo. any help appreciated.
  • pureheart Feb 24, 2008
    I did a system restore but not that far back only to Feb. 16. Charter comm. is my ISP but I also have Prodigy and AOL. Silly I guess to have all 3, I have windows xp. If I uninstall connection manager would that not just screw up everything? I do not have a disc to reinstall. Everything)programs) goes thru the yahoo actually thru Prodigy. I have had it for years and kept it because it was my business address. Don't really need it now, I guess....I did go thru administrator and services to check to see if anything had quit running and got all of that fixed. I do appreciate any advice on this maatter....thanks so much...........
Is your ISP providor AOL? Do you have ActiveSync installed (Ghost). Have you tried uninstalling your connection manager software and loggin in?
Erasing your cooking and history wouldn't stop your connection manager from running. There had to be something else that was deleted or uninstalled as well.
Are you running windows Xp and have you tried doing a System Restore to the point before the connection manager problem started?
Run System Restore to approximate 2 week prior to the problems you were having with Connection Manager!
Posted on Feb 23, 2008
    Scholar:
  • 117 Answers
Are you on dial up, dsl or cable modem. Do you have a firewall installed? Please give a more detailed explanation of whats happening...
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Feb 24, 2008
    Ok...even though Charter is your ISP..you are connecting through Yahoo and Prodigy?
    Connection manager is Microsoft's way to organize and
    automate network connections...
    I take it you are using a pocket pc, thus the problems with connection manager.
    Types of Connections
    Connection Manager offers two types of connections - The Internet and
    Work. These are used for specific reasons depending on the features you
    need in your connections. Here is a table of the functions and what option
    to choose:
    Function
    The Internet
    Work
    Internet Access
    Allows for direct internet access
    Requires the user to check the option that
    the connection allows internet access.
    Proxy Server
    Does not support a proxy server
    Supports a proxy server
    Socks or Winsock Support
    Does not support Socks or Winsock
    Supports Socks or Winsock for internet
    access
    Virtual Private Network (VPN)
    Does not support a VPN
    Supports a VPN to
    access the intranet, only when selected in the
    second list box.
    Network Synchronization with ActiveSync
    Does not support
    network synchronization
    Supports network synchronization
    (Requires ActiveSync 3.x only. Except Windows Mobile 5.0
    devices)
    Host Access
    Names with periods in them (DNS style
    or FQDN) on the internet
    Names without periods in them (WINS style)
    on the intranet
    You can always add your own type of connection such as when you need to
    connect to different companies networks.
    Applications that Support the Proxy Server Setting
    The following applications support the proxy server setting in the
    Connection Manager:
    • Pocket Internet Explorer
    • MSN Messenger
    The applications that does not use the proxy server settings in the
    Connection Manager are Windows Media Player and Microsoft Money. So
    make sure you configure it separately if you want to use Windows Media
    Player or Microsoft Money through the proxy.
    VPN Support
    The concept behind the VPN support is that whenever you need to connect
    to a host without a period in it's name and you have enabled a VPN connection and you are not
    connected directly to your network, the VPN connection
    will automatically be started. This occurs when you access a network
    share, Exchange Server, or a Proxy Server (IE: any host without a period
    in the name). Also, if you leave the VPN settings blank, the system
    will not attempt a VPN connection so you can use the Work settings for
    dialup or a home connection.
    One critical note about VPN connections are that they are only opened
    when a request to a host without a period is made and you are not on the
    same subnet as the host. Further the VPN is closed when a request is
    made to the internet. So the VPN connection does NOT support a split
    horizon.
    Recommendations
    I recommend that users consider just configuring all their connections
    under Work. That way they can connect to the internet, use a proxy server
    and access local resources without having to think about these
    settings. To do this you need to check the box under Proxy Settings
    that this "This Network Connects to the Internet". Make sure you
    only check the option to use a proxy if you need it.
    By configuring your connections this way, you can use a proxy at home
    and still get connected to the internet as needed. Also, this will allow
    you to use any connection you have defined under Work to connect to your
    VPN as well. If you need access to two networks, then I suggest
    adding an additional type of setting for the second network. This is done
    by clicking on the drop down box under the option for Work and selecting
    NEW. Then you can configure all the same settings for the connection as
    the default Work connection supports.
    Connection Scenarios that are Not
    Supported
    After reviewing the functionality of the Connection Manager, I have
    identified the follow scenarios where Connection Manager will not provide
    you with seamless connectivity:
    1. Any company that uses a DNS internally will not be able to access
      full DNS named hosts internally. This is due to the design that
      requests for all names with periods to go to the internet (drop down
      number one), not the Work connection (drop down number two) which is
      where Work points to. I know that major corporations with internal DNS
      based names will have this problem for example. There is no option to
      connect to both hosts via the same connection. The user has to switch
      between Work and The Internet in drop down box number one to get to
      those resources.
      Except with Windows Mobile 5.0 devices. There is an option in
      the Connection Manager to specify DNS named hosts that are internal.
      See above.
    2. Any user or ISP that uses a proxy and still connects directly to the
      internet will not work. The proxy assumes all connections with a
      dot in the name go to the proxy and that the proxy supports socks or
      winsock to connect. So company's that use a proxy to speed up
      access to the internet like when you use wireless will experience
      issues with e-mail due to this issue. So with the connection to
      Work, you can get to the web but no other
      service. So if you set it to The Internet then you can get
      e-mail but no web.
    The workaround to access e-mail is to use the IP address of the e-mail
    server instead of the host name in configuring the mail connection.
    Also, this will work for web servers as well for their default home
    page. By using the IP address the system will always get to the host
    regardless of the connection.
    What's Missing?
    Apparently, Microsoft did not plan for common issues that users will
    experience when using connectivity. Microsoft really
    needs to clarify why users need two different default connections - Work
    and The Internet. Further the ability to configure the connections for all
    possible options is very cumbersome. Microsoft needs to really work on
    making this experience much easier for the user.
When I Try To Sign In, It Says "Messenger Encountered A Connection Problem, Please Check The Network Connection And Then Click "Try Again", (81003004)
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Dec 30, 2010 | Yahoo Messenger
Yahoo messenger encounter problem - when login yahoo messenger disappear soon.i loaded 10 yahoo messenger pc to pc talk version.
yes,. this problem is encountered by a lot of users. this is the problem with your internet network connection, either ask the internet service provider for better option or download and use the older version of yahoo messenger from http://www.brothersoft.com/yahoo-messenger-66799.html
Oct 31, 2010 | Yahoo Messenger
Compaq Presario CQ40 laptop the fan functioned buit the screen won't work. Caplocks and numlock lights blinking on.
It sounds like a short or loose connection. If you're very savvy, you could fix it your left. However, frankly, if you were you would be coming to us. I'l suggest taking it is for services.
Jun 17, 2010 | Computers & Internet
Yahoo messenger prblem
try to go into preferences and change the proxy settings to firewall with no proxies and see if that works, if not uninstall it and download another yahoo and install it
Jul 14, 2009 | Yahoo YHT-630 System
When i try to log into yahoo messanger....
have you changed your firewall settings recently?
Maybe the firewall is preventing the connection. or if all is not working, try uninstalling the messenger and installing it again.
Jul 12, 2009 | Yahoo YHT-630 System
When logging on it says it has encountered a connection problem with the error number 81003004
Try selecting the 'Messenger' dropdown at the top of the window and selecting 'Connfection Preferences' and then select 'Connect via a Proxy Server'. Choose 'HTTP proxy' and then click ok. Try to log in again.
May 12, 2009 | Yahoo Messenger
I cant log into my yahoo messenger
internet explorer might be offline... open iternet explorer and connect it to the internet... it worked for me
May 03, 2009 | Yahoo YHT-630 System
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Feb 26, 2009 | Yahoo Messenger
Internet connection.. using yahoo messenger messenger encounter connection problem. please check the network connection and then click "Try again". (81003004)
Jan 14, 2009 | Yahoo Messenger
Computers & Internet Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
