Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak 5300 wont print on glossy side of photo paper
I put photo paper in tray glossy side down as per instructions. Printer spits seet out unprinted and says paper loaded upside down. I turn paper over with glossy side up and printer will print but it is on the back (dull side). What do I do?
  • 2 more comments
  • underthe arc May 02, 2008
    I have the same problem it wont print on glossy side of A4 photo paper, can you tell me where the answer to this problem is
  • Anonymous Jun 01, 2008
    I have the 5500 and have the same problem. It works fine for 4 x 6, but the 8 1/2 x 11 says to turn the paper over (duh who wants to print on the wrong side? but it works that way.)
    I have reset, reprogrammed, reloaded firmware etc. No luck.
    Wrote Kodak.....
    Help!
  • Anonymous Jul 22, 2008
    Yep same problem here with my 5300
  • SDtester
    SDtester May 11, 2010
    First of all thats not good for you or kodak.. first off what tray (bottom or small 4x6) are you printing from? second what brand of paper are you using?
    First you should try to update the printers Firmware.. open home center then click the ? and click maintenance then click the firmware upgrade button. even if the version is the same run the update anyway incase the firmware was corrupted.
    If that doesnt work respond to this request and I will try and find a sollution.
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Posted on Oct 10, 2008
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
How do u put the print paper in facing up or facing down printer photosmart c4750
If ordinary paper it does not matter.If photo paper then put it in the feeder tray glossy side down and one sheet at a time as glossy paper tends to stick and causes paper jams.
May 04, 2010 | HP Office Equipment & Supplies
Printer will not print properly, say photo tray not engaged.
take out the photo tray if you can and put it back into its place /
turn off the printer and turn it back on . if it works fine if it does not ,the sensor is bad .
it gives you this message only if the paper try is not inserted properly or it is a false error message .
Aug 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 aio printer won't print black
It is the print head. Cleaning the heads does not do any good, either does replacing the ink. What you'll need to do is contact Kodak's customer service line and they can replace it for you free of charge. On this site everyone seems to be saying it is consistently the black that stops, however, based on what Kodak said it is possible that either the black or the color can have this same issue.
When you call in they will ask you for your service number, which is located on the bottom left corner of the machine, when you lift the lid (as if you were going to replace the ink). They didn't ask me when I bought it, how much I used it, etc.
They will set up a case for you - it takes 2-3 business days for the print head to arrive. They will provide you with an invoice number as well. Be sure to document it all just incase the head never comes, or if there are additional issues after you receive it (and/or if it doesn't solve the problem)
Feb 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I CANT LOAD THE PAPER
I have just figured it out!!! You of course know to lift the cover......inside there is a slider to match the size of paper that you are using. I am using glossy photo paper 4 x 6. Glossy side up on the right side of the divider......and press print!!! Not explained anywhere in the instructions......this was after much trial and tribulation.
Sep 27, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
448 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
