Question about Denon AVR-786S Receiver
Denon AVR-786S 7.1 Channels Receiver
When we switch the receiver to DVD there is no sound. We just started having problems after DISH came and changed out our box. We have double checked all the connections. Not sure if something got changed on the receiver or remote. Help.
  • 10 more comments
  • Anonymous Mar 11, 2014
    mamas and papas rita cot bed nuts and bolts missing
    2002 nessan sentra wont shift out of low gear
    I have a pioneer vsx 07tx when I go to system setup it doesn't let me make any adjustments and the fan doesn't seem to work
    Htc one cell phone won't sync to my tablet
    labs inc 10225
    2006 kia sportage 2.7 valves
    Can you use pad air on kodak ESP C310
    i cant make a call without the call being dropped and phone attempts to redial caller
    hola necesito poner la cadena del tiempo del motor 2.4 del gran am 1999 cual es la posision donde deben de quedar los puntos
    Car dont start,have code p1351
    how do I set the digital clock on my 2012 town & country van?
    I bought a 1968 ford mustang. The previous owner glued the rear view mirror bracket mount on backwards. How do I remove the mount without breaking the glass so that I can properly install rear view mirror?
    Genius:
  • 3,422 Answers
First set the DVD player To mono and then see.
Check if the DVD assigned to coaxial input in receiver menu?
Check if the Digital out activated in player menu?
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.
Goodluck..
Posted on Feb 23, 2008
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
dennis
Feb 02, 2009 | Denon AVR-1708 Receiver
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
No sound for TV AVR 786
Check cables, see if other audio sources work through audio input ports.
Apr 24, 2008 | Denon AVR-786S Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Denon AVR-786S Receiver Logo
126 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
