Question about Behringer EUROPOWER EP2500 Amplifier
Behringer PMX 2000 Amplifier
I am trying to find a part for a Behringer PMX 2000 Amplifier. The part is called the IC and these are the IC numbers and I would like to order two each. Please let me know how I can locate this part and if u have a phone number so that I can call you.My email address is aliciadarwin618@yahoo.com
IC#
C5200-0
351
IC#
A1943-0
402
  • 1,512 Answers
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Posted on Feb 29, 2008
How do i hook up my laptop and my tablet to a behringer Europower PMX 2000
Easy to do - just get a patch cord that has a stereo 1/8" plug on one end and two phono (RCA) plugs on the other end. Plug the phono plugs into the "Tape IN" jacks on the mixer and use the "Tape" volume to adjust the sound level. It's best to turn your laptop or tablet volume up to maximum, then adjust the volume on the mixer.
Jan 15, 2015 | Behringer Audio Players & Recorders
Behringer Vintiger GM110 guitar amplifier Output pcb board
You should be able to get a diagram from the company itself and the circuit board can either be purchased from the manufacturer itself or they can tell you who to call.
Here is the manufacturer's number
BEHRINGER USA beusa_t.jpgBEHRINGER USA Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
you can also try their online support at
http://www.behringer.com/05_support/webform_support.cfm?lang=ENG
but I would just call them, it would be much easier
Let me know if you need any further help or if they couldn't help you and I will let you know who else might have what you need.
good luck
May 23, 2008 | Behringer Audio Players & Recorders
Will my Behringer amp purchased in the USA work in Australia
You will probably need a voltage converter. Unless you purchased the general export model with a switchable voltage power supply, your PMX2000 will have the power supply for the 120V 60 Hz electrical mains and a 10A H fuse. To confirm this, look on the back of the amp.
I wish that I had better news for you.
Jul 19, 2013 | Behringer Audio Players & Recorders
Behringer XENYX 1202FX Mixer
It is possible one of the IC's failed.
You can apply an audio signal to the input and with a small amplifier with speaker you can trace through the circuit to locate which IC failed.
The input to the small amp split iattach 2 wires pr test least leads from a meter, ground the ground lead of the little amp to the mixer chassis, and then with the other wire/test lead trace the defective channel 1 IC at a time until you lose signal.
If you download the IC's data sheet, Most likely a 4558 typse, you can speed the testing by simly testing at the amplifier inputs and output of each section of the IC. When you lose the signal, you found the offending IC- use the other channel for compairison.
Digikey has a site search, so you can enter the number on the IC to find if they carry it, or a similar IC, and who makes it- on the item specification page there is a link to the datasheet. While they may not have all of them, they have quite a few.
http://www.digikey.com
Apr 01, 2012 | Behringer Music
I have a behringer pmp 880s powered mixer it has a blown IC chip In need the part number.
Please note that there are many chips in the Behringer devices and we can't guess what the chip might be since we have no idea where it is in the unit.
HINT: There are MANY circuits in common in the lines of music equipment. See if the circuit board has a part number as well. The board may be in common with other PMP boards.
Also note the chip location, such as IC12 and also tell the type, Thru hole or surface mount, and the number of leads and ANY number on the chip.
Apr 24, 2010 | Behringer EUROPOWER EP2500 Amplifier
I need a circuit diagram for a Behringer PMX 2000 to repair a left hand power output problem
Here you go..
I posted your schematic on my temporary web files site; so,
download and save within the next two weeks cause it might go away..
http://ca.geocities.com/artiedc/PMX2000.pdf
Ed
Jun 21, 2009 | Audio Players & Recorders
Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Mar 17, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
BEHRINGER EUROPOWER pmx 1000
The voice cancellor switch basically subtracts the left and right signal because the vocalist is usually centered... The noise would likely be in an op amp associated with this feature...
Compare your circuit to a PMH1000. On that unit first thing to check is the two electrolytic caps at the left and right noise cancellor outputs.
There are a wholle bunch of resistors and IC's 48,50,37 are all involved.
Troubleshoot this one with freeze mist (ccircuit cooler). The problem should show up easily by heating and cooling.
Oct 29, 2008 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Behringer EUROPOWER EP2500 Amplifier Logo
465 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
