SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
SOURCE: handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
SOURCE: How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
Also check the widget that holds the handset in place when the phone is wall mounted. I just encountered this problem, and it turned out that widget was installed upside down, and was preventing the hook switch from disengaging completely.
