Question about Dishwashers
Grinding Noise This dishwasher, the "quiet power II", makes quite a loud racket while in wash mode. I would call it a grinding noise. Sometimes, I can hit the front of it and it will stop, other times not so. And even sometimes, we can do two or three loads and the noise doesn't happen. (not often)
  • kirbster71 Feb 23, 2008
    I read some other posts and found several with the same problem. Seems to be a common problem with this model. They said that its an easy fix...by tying the middle spray hose to the bottom of the top basket with some wire ties. I did and will see if it works. Thanks!
This is a definite fix for this problem! I used one wire tie to afix the pipe from the back of the dishwasher to the middle spray arm and wa-lah! The annoying noise is gone!
Posted on Feb 03, 2011
    President:
  • 2,651 Answers
You an remove lower access panel run d/w and nextime it makes the noise grab a flashlight and take a look under. sounds like a vibration issue( especially since you hit it nad it stops) perhaps your copper water line is rattling or your drain line is hitting motor causing noise
Posted on Feb 23, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My dishwasher makes a loud noise during wash cycle. quiet during filling and draining.
Could be a matter of how much is loaded in the racks and how it is placed. Something that is loosely loaded or located where the spray from the wash arm hits it can make quite a racket
Sep 17, 2012 | Frigidaire Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
    In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
    Oct 18, 2010 | Xerox Phaser 6360DN Printer
    When washer is started make loud grinding noise
    Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
    Reply back and we can you more.
    Dec 13, 2009 | Dishwashers
    Loud noise
    Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
    Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
    My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
    Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
    Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
    I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
    Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
    Our dishwasher is making a loud noise during wash cycle.
    if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
    Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
    Dishwashers Logo
    708 people viewed this question
    Top Dishwashers Experts
    Marvin
    Marvin
