Williams wall non-elec gas heater. Black copper wire tagged thermostat?
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
  • Anonymous Nov 22, 2008
    not sure where the wires (2) go on the bottom of williams gas heater. Have simple mercury thermostat. Thanks
    Sergeant:
  • 288 Answers
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Posted on Mar 02, 2008
Having problems with 35,000BTU Williams Wall Heater. Have changed thermostats twice using the 986-1R. Heater not coming on when dips down to lower temp and not shutting off when on just keeps runnin
Wall furnaces operate on millivolts of electricity, about 750 mv which is only 3/4 of 1 volt, 1000 mv being 1 volt.
The electricity is created by a pilot generator that is in your pilot assembly, the pilot generator has a hot end in the pilot flame and a cold end that is not in the flame, this temperature differential is how the pilot generator creates the 750 mv or 3/4 volt.
As this is not much voltage, it is very easily disrupted by a patina on the connections, wires and terminals, I would clean them all shiny new, this often will fix it, if not try jumping the 2 thermostat terminals that the thermostat wires are connected to, this bypasses the thermostat and wiring so if it runs you know why it was not before. The pilot generator likely needs to be replaced, you can test the gas valve with a AAA battery with a wire taped on each end, then wire the battery to the gas valves terminals that the pilot generators wired to, this simulates a good pilot generator.
If the system operates via battery do not use it this way it is not safe as no pilot safety exists in case the flame blows out! gas will still flow due to the battery powering the heaters valve, it is for testing only, if it works by battery then the pilot generators bad.
Jan 07, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
Williams wall heater, lite pilot and heater comes on okay, but will only come off when I disconnect the thermostat?
If you have to disconnect the thermostat wire at the gas valve then it is either a shorted thermostat or a short in the thermostat wire.
If you only have to disconnect the thermostat from the wire, then it sounds like a bad thermostat, replace the thermostat
Apr 11, 2013 | Williams 2509612 Ceramic Mid-Size Heater
How do you wire the thermosat on williams wall furnace model 3509622
This heater has 2 type gas valves one valve has the thermostat built into it. No wiring needed for that puppy. Looks like this:
So I am guessing that one ain't you.
Your heater must use a millivolt gas valve with the 2 wire wall thermostat. The pilot generator does 2 things. It holds the pilot on and it produces voltages that operate the solenoid and open and close the valve when the room thermostat makes contacts. So what goes wrong with these? The pilot generator will sometimes hold the pilot flame but whn the 2 wires are touched together or you tun on the wall thermostat the whole thang just dies. That my friend is a weak thermopile generator. The other thang that goes wrong is the solenoid on the gas valve is open and therefore the gas won't come on. Their is also a fuse mounted on there that melts and kills the magnet that the generator holds in for the pilot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Williams wall furnace 5009622 the pilot light will not stay on
The thermocouple is bad and needs to be replaced...
The thermocouple is the copper rod that sticks up into the pilot flame and then screws into the gas valve...
they are sold by lentgh so you need to measure the old one when you go to buy a replacement...
heatman101
Jan 06, 2011 | Williams (5009622) Ceramic Gas Wall...
One of the thermastat wires attaching to the williams heating on the wall became loose from the screw and didn't seem to be making little of no solid contact like a car battery might due. i tightened the...
If it touched a grounded metal surface, it is possible, leave the wires hooked up at the furnace, pull the thermostat off of the wall, disconnect the 2 thermostat wires, and then twist them together, the furnace should fire, if it does, then the thermostat is shot. Replace the thermostat, usually when there is a short, it burns out the heat anticipator on the thermostat.
Good Luck,
Paul Gibson
Apr 03, 2010 | Williams 1403622 Gas Compact Heater
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
We have a Williams wall heater that was gas/ converted to propane that is newly installed. The thermostat does not work. Any suggestions?
Assuming the pilot is lit, try jumping out the thermostat wires where they come into the valve. A paper clip would work. If it works, the problem is in the t-stat circuit.
Dec 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
I have model#2509622 Williams wall heater. I just installed it and the pilot lights fine. There is a copper ground wire, but the only way the furnace will fire up is when the ground wire is in contact with...
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Oct 09, 2009 | Williams 1403622 Gas Compact Heater
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Williams wall furnace, top vent.
Dec 13, 2007 | Heating & Cooling
Heating & Cooling Logo
983 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
