GE front loading washer leaking
My GE frontloading washer started leaking water from the bottom of the door. Help!
    Scholar:
  • 57 Answers
With only a limited amount of information, I would guess your door seal may be worn....but how can you check it? Take a reqular piece of paper (8.5x11) and cut a strip 1x11. Open the door and while holding onto the paper strip, put the strip in the TOP of the door and shut it to see how the seal 'feels' when you try to pull the paper out. It should be very hard, if not impossible to pull the strip of paper out. Now, do the same thing with the bottom of the door. Does it appear to be much easier? Without knowing the age of the machine, I might question the door seal. You might also want to check to see if the door might not be bent just a bit. Do this by placeing a long level vertically along the front facing with the door open, then check the door for level. It may be as simple as bending the top of the door out while you bend the lower part in.
Good Luck
Posted on Feb 23, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My frontload washer started leaking water through the front door. I checked the filter at bottom and it is not plugged. What should I check to fix this problem?
Make sure the rubber seal around the door is not a) pinched and bent out of shape b) degraded/deteriorated/ripped/cracked.
Also make sure no one knocked anything and bent anything out of shape.
Is your washer draining properly, otherwise?
May 06, 2011 | Kenmore HE2 Plus Front Load Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
