Question about Refrigerators
Wine cooler temperature control
This is a two zone system - one side seems to be about 4-5 degrees cooler than the setpoint, but still regulates around the colder temperature. The readout flips frequently up and down one degree. Are these normal, or signs of problems?
  • Anonymous Sep 10, 2008
    does the temperture of wine coolers fluate with room temps
    President:
  • Refrigerators Master
  • 2,651 Answers
Toatlly normal operation, realize that the machine needs to shut off/ on to regualte temp, new electronic thermistors are sensitive enought to detect miute temp flux, i wouldnt be concerned about this
Posted on Feb 23, 2008
What is a single zone wine cooler?
Single zone wine coolers have one temperature control and the storage space is undivided so the whole cooler is at the same temperature.
Aug 14, 2012 | Furniture
I just bought a dual zone wine cooler. What temperatures should I set both compartments to?
Red wine should be stored between 58-68 degrees Fahrenheit and the whites should be cooled at 46-56 degrees.
Jul 31, 2012 | Furniture
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Noisey, loud shrill
If you just got the unit you should contact your dealer for warranty service. The only noise you should hear is a slight hum of the compressor and the soft blowing noise of the condenser fan. It sounds as if the evaporator fan on this unit is toast. That is also why is it having a hard time maintaining temperature. The temperature indicated is actual air temperature sensed so it will go up and down a couple of degrees above and below setpoint but when operating correctly the product temperature will be very stable.
If the servicer does not fully understand the new digital system, make sure he/she contacts the factory technical assistance rep. at 800-428-6644.
Jul 16, 2009 | Marvel (6SBARBSG) Wine Cooler
The door was not shut good, so i turned the wine cooler off and defrosted it overnight, but i still have E5 error code flashing.
e-5 means that the unit is 10 degrees warmer then setpoint. If you just close everything up and let it run the e5 should disappear when it gets within the temperature.
Apr 25, 2009 | U-Line 15WC Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
