You might clean out the registry of any left over values. Try it on another machine if it still does it, its something mechanical inside maybe stuck. I suppose its out of warranty? You cant fly with those stickers anyways if that's what you do. Scourer the junk shops for an old MS Sidewinder, they are still the best stickes ever made.
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
Your in luck I happen to be a Flight simmer also. You need to go into your main menu under settings in Flight sim 2002. You will see enable joystick then you will see cordinated flight or uncordinated flight. You want to select uncordinated flight. Meaning that you will have full control of rudder and the sim will no longer make coordinated turns for you. You will have to add rudder to prevent a skid.
