Question about Zenith Z25X22S 25" TV
Channels Missing In Lineup
My remote control currently doesn't work. When I turn my TV on manually I find that Channels 2 and 3 are missing from the line up. The Auto Demo comes on and goes through the entire menu also and I can't stop it. I have
Brighthouse Cable in St. Petersburg, Florida. Please tell me how to fix these problems.
Beverly Nelmes
I cleaned a terminal inside my remote. It worked. I simply pushed 2, then Enter,
3, then Enter. I clicked Menu, scrolled down to Auto Demo, clicked arrow pointing right, and then entered "Off". Everything is solved.
BevN
Posted on Feb 26, 2008
Tv channels jump
Contact the service provider to Dish. This is not the fault to your TV. They should make it clear. Gopakumar Gopalan Google
Feb 24, 2014 | DISH Network Televison & Video
SRP4004/27
Let's try to sort this out. You have a universal remote control which you want to use with your RCA TV. You turn on the TV, press and release the TV button on your remote, and enter an RCA TV code. You then press the ON-OFF (or POWER) button and the TV turns off. If not, you repeat the process with other codes until you find one that turns the TV off. If you are successful, you should be able to turn on the TV and channel up or down through all available channels in your area. If I am missing something, post a reply
Nov 16, 2012 | Televison & Video
Failed to receive broadcast e202
The 202 error is usually associated with a bad cable card. In your case, you need to check and see if you have one.
Did you run the Autoprogramming required to load and store the Channels?
If you are attempting to Add digital cable to your TV lineup, you must do that.
And one note -- the digital stations on your TV set will not match the lineup on the Cable box. The box was designed to line up the TV stations according to the guide, but it uses proprietary programming software and hardware to do that.
TV's cannot use the software. so you end up with the low to high frequency channels in your lineup, but it's not similar to the cable channel's lineup.
Try finding USA or TNT lickety-split....you won't.
After doing the full autoprogramming, let me know if you get only the Analog Channels from your Cable provider, or if you get NO channels locking in at all. Either one will likely require replacing the Digital tuner module.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 18, 2011 | Sharp Televison & Video
Cannot change the channels !!!
press menu button....change autotune to manual channel set ...then just add the channels you want
Nov 28, 2009 | JVC AV-27D305 27" TV
Tv missing remote. bwant to watch cable tv
many of these require an original remote to program the catv and other functions---check ebay with your model number and see if you can get one.
Aug 06, 2009 | Televison & Video
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Missing plastic circle: remote doesn't function
If the remote sensor cover is missing on the TV, the remote would still work but you may get other effects like the TV changing channels on it own.
This is due to stray infra red signals.
If it's not working at all I would suspect the remote control handset.
You can test it by pointing it at a digital camera lens and watching the display screen on the camera.
You should see white light comming from the remote when you press any of the buttons if it's working.
Digital cameras can see infrared.
Mar 13, 2008 | Televison & Video
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Sep 04, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
151 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
