Question about Singer 3116 Simple
Handwheel not moving
It's almost a new machine. I haven't used it much either. After around 6 months I took it out and want to use it. But the hand wheel is not moving counter clockwise and it is not working. Pl help me.
  • 1ab2 Feb 23, 2008
    I checked for the thread...and don't see anything jammed. Can I do anything else?
  • 27 Answers
Check for a thread jam in and around the bobbin case.
Posted on Feb 23, 2008
How do you remove thread caught in hand wheel in babylock?
Take a good look in your manual and see how to clean and oil you machine. Now, take a new paint 2" brush(from Dollar store) and really brush that thread, when you get a little tail slowly pull it while turning the handwheel slowly is the key. Use tweezers if you need too. Keep going until you have no more thread, remove bobbin and cut the thread attached to the machine.
Nov 20, 2017 | Sewing Machines
How can I fix a stuck needle bar on my Bernina 730?
If this is a Bernina 730 Record, it needs to be cleaned and oiled. Do not attempt to run the motor if the mechanics are stuck as it could damage the motor.
Consult your owner's manual in the Maintenance section, use only good quality sewing machine oil (NOT old stale oil, 3-in-1, WD-40, or cooking oil) and apply 1-2 drops every place that metal rubs on metal (while you hand-rotate the wheel). Pay particular attention to your problem areas--the needlebar area and the handwheel area (Do NOT oil the cams, the belts, or the plastic gears!!) To speed it up, you can direct hot air from a handheld hairdryer into the internal mechanics. (You may have to repeat several times over several days depending how "stuck" things are.)
If you are impatient, try to find a bottle of liquid Tri-Flow Synthetic Lube at the hardware store or bike shop and use it in place of the sewing machine oil. Once the machine is running smoothly again, you can use sewing machine oil or continue to use Tri-Flow in its place.
In the future, following the instructions in your manual, clean and apply 1-2 drops oil to the shuttle/race every time you change a bobbin (about every 8 hours of constant sewing), do a thorough but light oil as explained above every 40 hours of sewing, or if in storage or not in regular use, every 6 months. If it hasn't been used in a while, always give it some TLC before asking it to work for you.
Sep 17, 2015 | Sewing Machines
Why is hand wheel stuck?
If it is a mechanical sewing machine (pre-1990), it most likely needs cleaning and oiling. (Old oil has turned to goo and is sticking things.) Consult your manual. Use good quality sewing machine oil (NOT 3-in-1, WD-40, cooking oil, or your grandmother's sewing machine oil). Apply only 1-2 drops each spot as instructed. Concentrate on the area around the handwheel since that's where your problem is, but the entire machine should be oiled. You can direct hot air from a handheld hairdryer into the interior mechanics to help loosen things. Let cool and test. Wiggle the handwheel and see if things have changed. Repeat oil/heat until your machine is working again. In the future, be sure to clean and oil every 8-10 hours of constant sewing or at least every six months if not in use.
Or take it for service to a good sewing machine repair service.
Aug 10, 2015 | Sewing Machines
The sewing machine was apparently used once for a small job and then put away. The next time it was to be used the hand wheel was found not to turn.
Sometimes, if the machine has not been used in a long while, the grease and oil can harden around the bearings and other metal moving joints. To get it moving again, a few drops of Triflow and a hot hair dryer aimed at the recalcitrant bearing while gently moving the hand wheel will start it moving. Just continue working on that point until it is freed up. A good cleaning would then be in order. I am assuming a vintage mostly metal machine for this answer, not a computerized electronic machine.
Jul 26, 2015 | Singer 2250 Portable Sewing Machine
How do I unjam the gears in my bernina 830?
If this is a Bernina 830 Record and the handwheel is stiff or does not turn, about 98% of the time the machine needs oil. Another problem could be a cracked or broken gear (one or both of the white plastic gears in the top but unless you are very handy, your Bernina tech should probably take care of this repair.)
Mechanical machines need to be oiled regularly just like your car. If the machine sets in storage for a while or is used often but not oiled or cleaned regularly, the oil that exists in the machine will eventually thicken and acts like glue. (Sometimes you can see a dirty-looking dark gold or brownish goop which is usually old oil.) Then your machine is frozen.
There are quite a few oil holes (both in the top and bottom of a Bernina mechanical) that require periodic oiling (see your machine Manual). If the handwheel is frozen, buy a bottle of liquid Tri-Flow Synthentic Oil (from the hardware store) and put one or two drops in all the spots shown in the manual. (DO NOT oil the two white plastic gears or the metal CAMs!!! NEVER use 3-in-1 oil, cooking oil, WD-40, or a generic sewing machine oil from the fabric store. And do not put more than one or two drops of oil at a time as over-oiling will also damage your machine.)
Then, using your hand-held hair dryer, direct hot air into the internal part of the machine (top and bottom). The metal may become very warm to the touch. Then try to gently move the handwheel. Repeat. Even letting it set overnight may help.
Once the handwheel loosens, slowly hand-rotate the handwheel and watch where metal parts move against each other, put a drop of oil in each of those. Be sure to move the selector knobs and oil where metal moves against metal to keep those working.
To maintain your machine, a good recommendation is to oil every time the bobbin thread is changed, every 8 hours of constant sewing, or every six months if the machine is not in use. Use a good quality oil, ie Bernina oil for "mechanical" machines. When oiling, also be sure to brush out the dust and lint (especially around the feed dogs and bobbin works).
If the oil in your tube looks dark colored, throw it out and get some new. I've run across some old sewing machine oil in the can that looked like dark honey and stunk to high heaven. Get rid of it!
Treat your machine well and it will serve you well for many years.
Jan 04, 2015 | Bernina Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
My needle does not go up and down.
You need to check the needle bar first of all to see if you can move it up and down by hand, if you can then the screw on the needle bar may have come loose, or the very worst situation could be a broken takeup lever
Jul 05, 2010 | Bernina Artista 170
Vintage new home (XR-VII model 990)sewing machine with a handwheel problem
Can you post a photo of the machine, cannot find a reference to this model.
1st just check around the bobbin case area for jammed thread, also in/around the *takeup lever (up/down arm) mechanism near needlebar, as thread often gets wound around and jams the shaft
If it really seems like corrosion in an elderly & neglected machine.... disconnect from power, and using a small rocking movement of the handwheel to identify the parts that should move and with all the covers removed and in a dry well ventilated area with old newspaper to absorb excess,
.......give a light spray of WD40 or similar penetraing lubricant on horizontal Top shaft at each end where it joins main body
..... the region that operates the *take up lever cranks and counterbalance
.....the handwheel has a clutch mechanism, so if you can undo the wheel to access this, it may well be dry and need lube.
.....In the base is another horizontal shaft lube each end and a little where the gears meet to change the drive direction under the hook race/bobbin.
With the same gentle rocking motion of handwheel, see if there is any improvement ...but do not force anything......(to stitch forward, the handwheel spins "over the falls" toward you)
You may not see immediate improvement, so leave overnight and be patient, it may take several days........just be very sure there is nothing jammed anywhere.
Feb 26, 2008 | Sewing Machines
Singer 3116 Simple Logo
236 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
